Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 445 12 Nov 2024
14/stable 444 12 Nov 2024
14/candidate 463 19 Nov 2024
14/candidate 462 19 Nov 2024
14/beta 463 19 Nov 2024
14/beta 462 19 Nov 2024
14/edge 465 20 Nov 2024
14/edge 464 20 Nov 2024
Reference > Release Notes > All revisions > Revision 73
Revision 73
Thursday, April 20, 2023
Dear community,
We’d like to announce that Canonical’s newest Charmed PostgreSQL operator for Kubernetes has been published in the 14/stable channel. :tada:
  • Deploying on Kubernetes (tested with MicroK8s, GKE)
  • Scaling up/down in one simple juju command
  • HA using Patroni
  • Full backups and restores are supported when using any S3-compatible storage
  • TLS support (using “tls-certificates” operator)
  • DB access outside of Juju using “data-integrator
  • Data import using standard tools e.g. “PostgreSQL Data Injector
  • Documentation
Inside the charms
  • Charmed PostgreSQL K8s charm ships the latest PostgreSQL “14.7-0ubuntu0.22.04.1”
  • K8s charms based on our ROCK OCI (Ubuntu LTS “22.04” - ubuntu:22.04-based)
  • Principal charms supports the latest LTS series “22.04” only.
  • Subordinate charms support LTS “22.04” and “20.04” only.
Technical notes
Compatibility with legacy charms:
  • The new PostgreSQL charm is also a juju interface-compatible replacement for legacy PostgreSQL charms (using legacy interface pgsql, via endpoints db and db-admin). However, it is highly recommended to migrate to the modern interface postgresql_client (endpoint database).
    • Please contact us if you are considering migrating from other “legacy” charms not mentioned above.
  • Charm PostgreSQL K8s charm follows the SNAP track “14” (through repackaed ROCK/OCI image).
  • No “latest” track in use (no surprises in tracking “latest/stable”)!
    • Charmed PostgreSQL K8s charms provide legacy charm through “latest/stable”.
  • Charm lifecycle flowchart diagrams: PostgreSQL.
  • Modern interfaces are well described in “Interfaces catalogue” and implemented by ‘data-platform-libs’.
  • Known limitation: PostgreSQL extensions are not yet supported.
Contact us
  • Raise software issues or feature requests on GitHub
  • Report security issues through Launchpad
  • Contact the Canonical Data Platform team through our Matrix channel.
