postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 559 15 Apr 2025
14/candidate 558 15 Apr 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 565 18 Apr 2025
14/edge 564 18 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 563 17 Apr 2025
Ubuntu 24.04
16/edge 562 17 Apr 2025
Ubuntu 24.04
Relations flowcharts
This reference documentation details the implementation of the database-peers peer relation. This is the peer relation for PostgreSQL, used to share user and config information from the leader unit to the follower units. The file implementing these relations can be found here: src/relations/charm.py (it should be moved to a file called src/relations/peers.py in the future).
Expected Interface
These are the expected contents of the databags in this relation (all values are examples, generated in a running test instance):
Hook Handler Flowcharts
These flowcharts detail the control flow of the hooks in this program. Unless otherwise stated, a hook deferral is always followed by a return.
Peer Relation Changed Hook
Click to navigate the mermaid diagram on GitHub.
Mermaid Diagram
no
yes
no
yes
yes
no
no
yes
no
yes
no
yes
peer-relation-changed Hook
Has cluster\n initialised?
defer
Is current\nunit leader?
Is current unit \n part of the cluster?
Are all the units \n part of the cluster?
Are all cluster \n members ready?
defer
Add unit to cluster
Patch pod labels of the new cluster member
return
Update Patroni and \n PostgreSQL config \n
Restart PostgreSQL \n if TLS is turned on/off
Have Patroni and \n PostgreSQL started in \n the current unit?
defer
Update the read-only endpoint \n in the database relation
Set Active\n Status
return
Peer Relation Departed Hook
Mermaid Diagram
no
yes
no
yes
Is leader and \n is not departing?
return
defer
Remove departing units \n from the cluster
Turn on/off PostgreSQL \n synchronous_commit configuration
return
Help improve this document in the forum (guidelines). Last updated 1 year, 10 months ago.
