Charmed PostgreSQL K8s
- Canonical
14/candidate | 559 | 15 Apr 2025 | |
14/candidate | 558 | 15 Apr 2025 | |
14/edge | 565 | 18 Apr 2025 | |
14/edge | 564 | 18 Apr 2025 | |
16/edge | 563 | 17 Apr 2025 | |
16/edge | 562 | 17 Apr 2025 |
How to enable monitoring (COS)
juju run
injuju v.2.9
juju integrate
replacesjuju relate
andjuju add-relation
injuju v.2.9
- A deployed Charmed PostgreSQL K8s operator
- A deployed
cos-lite
bundle in a Kubernetes environment
Offer interfaces via the COS controller
First, we will switch to the COS K8s environment and offer COS interfaces to be cross-model integrated with the Charmed PostgreSQL K8s model.
To switch to the Kubernetes controller for the COS model, run
juju switch <k8s_cos_controller>:<cos_model_name>
To offer the COS interfaces, run
juju offer grafana:grafana-dashboard
juju offer loki:logging
juju offer prometheus:receive-remote-write
Consume offers via the PostgreSQL model
Next, we will switch to the Charmed PostgreSQL K8s model, find offers, and consume them.
We are currently on the Kubernetes controller for the COS model. To switch to the PostgreSQL model, run
juju switch <k8s_db_controller>:<postgresql_model_name>
To find offers, run the following command (make sure not to miss the “:” at the end!):
juju find-offers <k8s_cos_controller>:
The output should be similar to the sample below, where k8s
is the k8s controller name and cos
is the model where cos-lite
has been deployed:
Store URL Access Interfaces
k8s admin/cos:grafana admin grafana:grafana-dashboard
k8s admin/cos.loki admin loki:logging
k8s admin/cos.prometheus admin prometheus:receive-remote-write
To consume offers to be reachable in the current model, run
juju consume <k8s_cos_controller>:admin/cos.grafana
juju consume <k8s_cos_controller>:admin/cos.loki
juju consume <k8s_cos_controller>:admin/cos.prometheus
Deploy and integrate Grafana
First, deploy grafana-agent-k8s:
juju deploy grafana-agent-k8s --trust
Then, integrate (previously known as “relate”) it with Charmed PostgreSQL K8s:
juju integrate grafana-agent-k8s grafana
juju integrate grafana-agent-k8s loki
juju integrate grafana-agent-k8s prometheus
Finally, integrate grafana-agent-k8s
with consumed COS offers:
juju integrate grafana-agent-k8s postgresql-k8s:grafana-dashboard
juju integrate grafana-agent-k8s postgresql-k8s:logging
juju integrate grafana-agent-k8s postgresql-k8s:metrics-endpoint
After this is complete, Grafana will show the new dashboard PostgreSQL Exporter
and will allow access to Charmed PostgreSQL logs on Loki.
Sample outputs
Below is a sample output of juju status
on the Charmed PostgreSQL K8s model:
welcome microk8s microk8s/localhost 3.1.6 unsupported 00:21:41+02:00
SAAS Status Store URL
grafana active microk8s admin/cos.grafana
loki active microk8s admin/cos.loki
prometheus active microk8s admin/cos.prometheus
grafana-agent-k8s 0.32.1 active 1 grafana-agent-k8s stable 42 10.152.183.61 no
postgresql-k8s 14.9 active 3 postgresql-k8s 14/edge 145 10.152.183.126 no
grafana-agent-k8s/0* active idle 10.1.142.191
postgresql-k8s/0 active idle 10.1.142.171
postgresql-k8s/1 active idle 10.1.142.169
postgresql-k8s/2* active idle 10.1.142.170 Primary
on COS K8s model:
cos microk8s microk8s/localhost 3.1.6 unsupported 00:21:19+02:00
alertmanager 0.25.0 active 1 alertmanager-k8s edge 91 10.152.183.215 no
catalogue active 1 catalogue-k8s edge 27 10.152.183.187 no
grafana 9.2.1 active 1 grafana-k8s edge 92 10.152.183.95 no
loki 2.7.4 active 1 loki-k8s edge 99 10.152.183.28 no
prometheus 2.46.0 active 1 prometheus-k8s edge 149 10.152.183.232 no
traefik 2.10.4 active 1 traefik-k8s edge 155 10.76.203.228 no
alertmanager/0* active idle 10.1.142.186
catalogue/0* active idle 10.1.142.176
grafana/0* active idle 10.1.142.189
loki/0* active idle 10.1.142.187
prometheus/0* active idle 10.1.142.188
traefik/0* active idle 10.1.142.185
Offer Application Charm Rev Connected Endpoint Interface Role
grafana grafana grafana-k8s 92 1/1 grafana-dashboard grafana_dashboard requirer
loki loki loki-k8s 99 1/1 logging loki_push_api provider
prometheus prometheus prometheus-k8s 149 1/1 receive-remote-write prometheus_remote_write provider
Connect Grafana web interface
To connect to the Grafana web interface, follow the Browse dashboards section of the MicroK8s “Getting started” guide.
juju run grafana/leader get-admin-password --model <k8s_cos_controller>:<cos_model_name>
