postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 559 15 Apr 2025
14/candidate 558 15 Apr 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 565 18 Apr 2025
14/edge 564 18 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 563 17 Apr 2025
Ubuntu 24.04
16/edge 562 17 Apr 2025
Ubuntu 24.04
Enable tracing
This guide contains the steps to enable tracing with Grafana Tempo for your PostgreSQL K8s application.
To summarize:
This feature is available for Charmed PostgreSQL K8s revision 292+ only.
Deploy Tempo
Then, deploy the dependencies of Tempo following this tutorial. In particular, we would want to:
  • Deploy the minio charm
  • Deploy the s3 integrator charm
  • Add a bucket in minio using a python script
  • Configure s3 integrator with the minio credentials
Finally, deploy and integratre with Tempo HA in a monolithic setup.
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed PostgreSQL K8s is deployed.
juju offer <tempo_coordinator_k8s_application_name>:tracing
Then, switch to the Charmed PostgreSQL K8s model, find the offers, and integrate (relate) with them:
juju switch <k8s_controller_name>:<postgresql_k8s_model_name>
:exclamation: Do not miss the “:” in the command above.
Store  URL                            Access  Interfaces
k8s    admin/cos.tempo                admin   tracing:tracing
juju consume k8s:admin/cos.tempo
Consume interfaces
First, deploy Grafana Agent K8s from the latest/edge channel:
juju deploy grafana-agent-k8s --channel latest-edge
Then, integrate Grafana Agent K8s with the consumed interface from the previous section:
juju integrate grafana-agent-k8s:tracing tempo:tracing
Finally, integrate Charmed PostgreSQL K8s with Grafana Agent K8s:
juju integrate postgresql-k8s:tracing grafana-agent-k8s:tracing-provider
Wait until the model settles. The following is an example of the juju status --relations on the Charmed PostgreSQL model:
database  k8s         microk8s/localhost  3.5.4    unsupported  16:52:21Z
SAAS   Status  Store       URL
tempo  active  k8s         admin/cos.tempo
App                Version  Status  Scale  Charm              Channel      Rev  Address         Exposed  Message
grafana-agent-k8s  0.40.4   active      1  grafana-agent-k8s  latest/edge   93  10.152.183.226  no       grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
postgresql-k8s     14.13    active      1  postgresql-k8s                    0  10.152.183.96   no
Unit                  Workload  Agent  Address       Ports  Message
grafana-agent-k8s/0*  active    idle   10.1.241.195         grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
postgresql-k8s/0*     active    idle   10.1.241.197         Primary
Integration provider                Requirer                       Interface              Type     Message
grafana-agent-k8s:peers             grafana-agent-k8s:peers        grafana_agent_replica  peer
grafana-agent-k8s:tracing-provider  postgresql-k8s:tracing         tracing                regular
postgresql-k8s:database-peers       postgresql-k8s:database-peers  postgresql_peers       peer
postgresql-k8s:restart              postgresql-k8s:restart         rolling_op             peer
postgresql-k8s:upgrade              postgresql-k8s:upgrade         upgrade                peer
tempo:tracing                       grafana-agent-k8s:tracing      tracing                regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore section with tempo-k8s as the data source. You will be able to select postgresql-k8s as the Service Name under the Search tab to view traces belonging to Charmed PostgreSQL K8s.
Below is a screenshot demonstrating a Charmed PostgreSQL K8s trace:
Feel free to read through the Tempo HA documentation at your leisure to explore its deployment and its integrations.
Help improve this document in the forum (guidelines). Last updated 2 months ago.
