Charmed PostgreSQL K8s
- Canonical
14/stable | 445 | 12 Nov 2024 | |
14/stable | 444 | 12 Nov 2024 | |
14/candidate | 463 | 19 Nov 2024 | |
14/candidate | 462 | 19 Nov 2024 | |
14/beta | 463 | 19 Nov 2024 | |
14/beta | 462 | 19 Nov 2024 | |
14/edge | 465 | 20 Nov 2024 | |
14/edge | 464 | 20 Nov 2024 |
Reference > Release Notes > All revisions > Revision 193
Revision 193
March 13, 2024
Dear community,
We’d like to announce that Canonical’s newest Charmed PostgreSQL operator for Kubernetes has been published in the 14/stable
channel.
- [CORE] PostgreSQL upgrade 14.9 → 14.10. (DPE-3217)
- Note: It is advisable to REINDEX potentially-affected indexes after installing this update! (See PostgreSQL14.10 changelog)
- [CORE] Juju 3.1.7+ support (#2037120)
- [PLUGINS] pgVector extension/plugin (DPE-3159)
- [PLUGINS] New PostGIS plugin (#363)
- [PLUGINS] More new plugins - 50 in total
- [MONITORING] COS Awesome Alert rules (DPE-3161)
- [SECURITY] Updated TLS libraries for compatibility with new charms
- manual-tls-certificates
- self-signed-certificates
- Any charms compatible with tls_certificates_interface.v2.tls_certificates
- All functionality from previous revisions
Bugfixes
- Stabilized internal Juju secrets management (DPE-3199 | #358)
- Check system identifier in stanza (backups setup stabilization) (DPE-3061)
Canonical Data issues are now public on both Jira and GitHub platforms. GitHub Releases provide a detailed list of bugfixes, PRs, and commits for each revision.
Inside the charms
- Charmed PostgreSQL ships the PostgreSQL
14.10-0ubuntu0.22.04.1
- PostgreSQL cluster manager Patroni -
v.3.1.2
- Backup tools pgBackRest -
v.2.48
- The Prometheus postgres_exporter is
0.12.1-0ubuntu0.22.04.1~ppa1
- This charm uses ROCK OCI (postgresql-image resource-revision 149) based on SNAP revision 96
- This charm ships the latest base
Ubuntu LTS 22.04.3
Technical notes
- Starting with this revision (193+), you can use
juju refresh
to upgrade Charmed PostgreSQL K8s - It is recommended to use this operator together with modern Charmed PgBouncer operator
- Please check the external components requirements
- Please check the previously posted restrictions
- Ensure the charm requirements met
Contact us
- Raise software issues or feature requests on GitHub
- Report security issues through Launchpad
- Contact the Canonical Data Platform team through our Matrix channel.
