postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 559 15 Apr 2025
14/candidate 558 15 Apr 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 565 Yesterday
14/edge 564 Yesterday
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 563 17 Apr 2025
Ubuntu 24.04
16/edge 562 17 Apr 2025
Ubuntu 24.04
Charmed PostgreSQL K8s Tutorial > 2. Deploy PostgreSQL
Deploy Charmed PostgreSQL K8s
In this section, you will deploy a postgresql-k8s application to your juju model and track its status.
Deploy PostgreSQL
To deploy Charmed PostgreSQL K8s, run
juju deploy postgresql-k8s --trust
--trust is required because the charm and Patroni need to create some K8s resources.
Juju will now fetch Charmed PostgreSQL K8s from Charmhub and deploy it to the local MicroK8s. This process can take several minutes depending on how provisioned (RAM, CPU, etc) your machine is.
Track application status
You can track the deployment by running:
juju status --watch 1s
This command is useful for checking the real-time information about the state of a charm and the machines hosting it. Check the juju status documentation for more information about its usage.
When the application is ready, juju status will show something similar to the sample output below:
tutorial  charm-dev   microk8s/localhost  2.9.42   unsupported  12:00:43+01:00
App             Version  Status  Scale  Charm           Channel    Rev  Address         Exposed  Message
postgresql-k8s           active      1  postgresql-k8s  14/stable  56   10.152.183.167  no
Unit               Workload  Agent  Address       Ports  Message
postgresql-k8s/0*  active    idle   10.1.188.206
You can also watch juju logs with the juju debug-log command. More info on logging in the juju logs documentation.
Next step: 3. Access PostgreSQL
Help improve this document in the forum (guidelines). Last updated 8 months ago.
