Charmed PostgreSQL K8s
- Canonical
14/candidate | 559 | 15 Apr 2025 | |
14/candidate | 558 | 15 Apr 2025 | |
14/edge | 565 | 18 Apr 2025 | |
14/edge | 564 | 18 Apr 2025 | |
16/edge | 563 | 17 Apr 2025 | |
16/edge | 562 | 17 Apr 2025 |
How to deploy on Canonical Kubernetes
Canonical Kubernetes is a Kubernetes service built on Ubuntu and optimized for most major public clouds.
This guide shows you how to deploy Charmed PostgreSQL K8s to Canonical Kubernetes.
This guide assumes you have a spare hardware/VMs running Ubuntu 22.04 LTS (or newer).
Install Canonical Kubernetes
The following instructions are a complete but summarized version of the steps for installing Canonical K8s. For more thorough instructions and details, see the official Canonical Kubernetes documentation: Install Canonical Kubernetes from a snap.
Install, bootstrap, and check the status of Canonical K8s with the following commands:
sudo snap install k8s --edge --classic
sudo k8s bootstrap
sudo k8s status --wait-ready
Once Canonical K8s is up and running, enable local storage (or any another persistent volume provider, to be used by Juju Storage later):
sudo k8s enable local-storage
(Optional) Install kubectl tool and dump the K8s config:
sudo snap install kubectl --classic
mkdir ~/.kube
sudo k8s config > ~/.kube/config
kubectl get namespaces # to test the credentials
Install Juju
Install Juju and bootstrap the first Juju controller in K8s:
sudo snap install juju --channel 3.6/candidate
juju add-k8s ck8s --client --context-name="k8s"
juju bootstrap ck8s
Deploy Charmed PostgreSQL K8s
juju add-model postgresql
juju deploy postgresql-k8s --trust
follow the deployment progress using:
juju status --watch 1s
Example output:
postgresql ck8s ck8s 3.6-rc1 unsupported 17:25:11+01:00
postgresql-k8s 14.12 active 1 postgresql-k8s 14/stable 381 10.152.183.30 no
postgresql-k8s/0* active idle 10.1.0.16 Primary
Next steps: Learn how to scale your application, relate with other applications and more.
