postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 559 15 Apr 2025
14/candidate 558 15 Apr 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 565 18 Apr 2025
14/edge 564 18 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 563 17 Apr 2025
Ubuntu 24.04
16/edge 562 17 Apr 2025
Ubuntu 24.04
How to migrate a cluster
This is a guide on how to restore a backup that was made from a different cluster, (i.e. cluster migration via restore).
To perform a basic restore (from a local backup), see How to restore a local backup
Restoring a backup from a previous cluster to a current cluster requires:
  • A single unit Charmed PostgreSQL deployed and running
  • Access to S3 storage
  • Configured settings for S3 storage
  • Backups from the previous cluster in your S3 storage
  • Passwords from your previous cluster
Manage cluster passwords
When you restore a backup from an old cluster, it will restore the password from the previous cluster to your current cluster. Set the password of your current cluster to the previous cluster’s password:
juju run postgresql-k8s/leader set-password username=operator password=<previous cluster password>
juju run postgresql-k8s/leader set-password username=replication password=<previous cluster password>
juju run postgresql-k8s/leader set-password username=rewind password=<previous cluster password>
List backups
To view the available backups to restore, use the command list-backups:
juju run postgresql-k8s/leader list-backups
This shows a list of the available backups (it is up to you to identify which backup-id corresponds to the previous-cluster):
backups:
      |backup-id           | backup-type  | backup-status
      YYYY-MM-DDTHH:MM:SSZ  | physical     | finished
Restore backup
To restore your current cluster to the state of the previous cluster, run the restore command and pass the correct backup-id to the command:
juju run postgresql-k8s/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ
Your restore will then be in progress. Once it is complete, your current cluster will represent the state of the previous cluster.
Help improve this document in the forum (guidelines). Last updated 10 months ago.
