Charmed PostgreSQL K8s
- Canonical
14/stable | 445 | 12 Nov 2024 | |
14/stable | 444 | 12 Nov 2024 | |
14/candidate | 463 | 19 Nov 2024 | |
14/candidate | 462 | 19 Nov 2024 | |
14/beta | 463 | 19 Nov 2024 | |
14/beta | 462 | 19 Nov 2024 | |
14/edge | 465 | 20 Nov 2024 | |
14/edge | 464 | 20 Nov 2024 |
Reference > Release Notes > All revisions > Revision 280/281
Revision 280/281
June 28, 2024
Dear community,
Canonical’s newest Charmed PostgreSQL K8s operator has been published in the ‘14/stable’ channel
Due to the newly added support for arm64
architecture, the PostgreSQL charm now releases two revisions simultaneously:
- Revision 281 is built for
amd64
- Revision 280 is built for for
arm64
Otherwise, it can be done at deploy time with the --constraints
flag:
juju deploy postgresql-k8s --constraints arch=<arch> --trust
where <arch>
can be amd64
or arm64
Highlights
- Upgraded PostgreSQL from v.14.10 → v.14.11 (PR #432)
- Check the official PostgreSQL release notes
- Added support for ARM64 architecture (PR #408)
- Added support for cross-regional asynchronous replication (PR #447) (DPE-2897)
- This feature focuses on disaster recovery by distributing data across different servers. Check our new how-to guides for a walkthrough of the cross-model setup, promotion, switchover, and other details.
- Added support for tracing with Tempo K8s (PR #497)
- Check the new guide: How to enable tracing
- Released new Charmed Sysbench operator for easy performance testing
Enhancements
- Added timescaledb plugin/extension (PR #488)
- See the Configuration tab for all parameters.
- Added incremental and differential backup support (PR #487)(PR #476)(DPE-4464)
- Check the guide: How to create and list backups
- Added support for disabling the operator (DPE-2470)
- Added configuration option for backup retention time (PR #477)(DPE-4401)
- Added message to inform users about missing
--trust
flag (PR #440)(DPE-3885) - Added
experimental_max_connections
config option (PR #500) - Introduced a block on legacy roles request (modern interface only) (PR#391)(DPE-3099)
Bugfixes
- Fixed large objects ownership (PR #390)(DPE-3551)
- Fixed shared buffers validation (PR #396)(DPE-3594)
- Fixed handling S3 relation in primary non-leader unit (PR #375)(DPE-3349)
- Stabilized SST and network cut tests (PR #385)(DPE-3473)
- Fixed pod reconciliation: rerender config/service on pod recreation (PR#461)(DPE-2671)
- Addressed main instability sources on backups integration tests (PR#496)(DPE-4427)
- Fixed scale up with S3 and TLS relations in (PR#489)(DPE-4456)
Canonical Data issues are now public on both Jira and GitHub.
For a full list of all changes in this revision, see the GitHub Release.
Technical details
This section contains some technical details about the charm’s contents and dependencies. Make sure to also check the system requirements.
Packaging
This charm is based on the charmed-postgresql
snap (pinned revision 113). It packages:
- postgresql
v.14.11
- pgbouncer
v.1.21
- patroni
v.3.1.2
- pgBackRest
v.2.48
- prometheus-postgres-exporter
v.0.12.1
Libraries and interfaces
This charm revision imports the following libraries:
- grafana_agent
v0
for integration with Grafana- Implements
cos_agent
interface
- Implements
- rolling_ops
v0
for rolling operations across units- Implements
rolling_op
interface
- Implements
- tempo_k8s
v1
,v2
for integration with Tempo charm- Implements
tracing
interface
- Implements
- tls_certificates_interface
v2
for integration with TLS charms- Implements
tls-certificates
interface
- Implements
See the /lib/charms
directory on GitHub for more details about all supported libraries.
See the metadata.yaml
file on GitHub for a full list of supported interfaces
Contact us
- Raise software issues or feature requests on GitHub
- Report security issues through Launchpad
- Contact the Canonical Data Platform team through our Matrix channel.
