Charmed PostgreSQL K8s
- Canonical
14/candidate | 559 | 15 Apr 2025 | |
14/candidate | 558 | 15 Apr 2025 | |
14/edge | 565 | 18 Apr 2025 | |
14/edge | 564 | 18 Apr 2025 | |
16/edge | 563 | 17 Apr 2025 | |
16/edge | 562 | 17 Apr 2025 |
How to deploy on AKS
Azure Kubernetes Service (AKS) allows you to quickly deploy a production ready Kubernetes cluster in Azure. To access the AKS Web interface, go to https://portal.azure.com/.
- Install AKS and Juju tooling
- Create a new AKS cluster
- Bootstrap Juju on AKS
- Deploy charms
- Display deployment information
- Clean up
Install Juju and Azure CLI tool:
sudo snap install juju
sudo apt install --yes azure-cli
Follow the installation guides for:
- az - the Azure CLI
To check they are all correctly installed, you can run the commands demonstrated below with sample outputs:
~$ juju version
3.4.2-genericlinux-amd64
~$ az --version
azure-cli 2.61.0
core 2.61.0
telemetry 1.1.0
Dependencies:
msal 1.28.0
azure-mgmt-resource 23.1.1
Your CLI is up-to-date.
Authenticate
Login to your Azure account:
az login
Export the deployment name for further use:
export JUJU_NAME=aks-$USER-$RANDOM
This following examples in this guide will use the single server AKS in location eastus
- feel free to change this for your own deployment.
Create a new Azure Resource Group:
az group create --name aks --location eastus
Bootstrap AKS with the following command (increase nodes count/size if necessary):
az aks create -g aks -n ${JUJU_NAME} --enable-managed-identity --node-count 1 --node-vm-size=Standard_D4s_v4 --generate-ssh-keys
Sample output:
"aadProfile": null,
"addonProfiles": null,
"agentPoolProfiles": [
"availabilityZones": null,
"capacityReservationGroupId": null,
"count": 1,
"creationData": null,
"currentOrchestratorVersion": "1.28.9",
"enableAutoScaling": false,
"enableEncryptionAtHost": false,
"enableFips": false,
"enableNodePublicIp": false,
Dump newly bootstraped AKS credentials:
az aks get-credentials --resource-group aks --name ${JUJU_NAME} --context aks
Sample output:
Merged "aks" as current context in ~/.kube/config
Bootstrap Juju controller:
juju bootstrap aks aks
Sample output:
Creating Juju controller "aks" on aks/eastus
Bootstrap to Kubernetes cluster identified as azure/eastus
Creating k8s resources for controller "controller-aks"
Downloading images
Starting controller pod
Bootstrap agent now started
Contacting Juju controller at 20.231.233.33 to verify accessibility...
Bootstrap complete, controller "aks" is now available in namespace "controller-aks"
Now you can run
juju add-model <model-name>
to create a new model to deploy k8s workloads.
Create a new Juju model (k8s namespace)
juju add-model welcome aks
[Optional] Increase DEBUG level if you are troubleshooting charms:
juju model-config logging-config='<root>=INFO;unit=DEBUG'
Deploy charms
The following command deploys PostgreSQL K8s:
juju deploy postgresql-k8s --trust -n 3 --channel 14/stable
Sample output:
Deployed "postgresql-k8s" from charm-hub charm "postgresql-k8s", revision 247 in channel 14/stable on ubuntu@22.04/stable
Check the status:
juju status --watch 1s
Sample output:
welcome aks aks/eastus 3.4.2 unsupported 17:53:35+02:00
postgresql-k8s 14.11 active 3 postgresql-k8s 14/stable 247 10.0.237.223 no Primary
postgresql-k8s/0* active idle 10.244.0.19 Primary
postgresql-k8s/1 active idle 10.244.0.18
postgresql-k8s/2 active idle 10.244.0.17
Display information about the current deployments with the following commands:
~$ kubectl cluster-info
Kubernetes control plane is running at https://aks-user-aks-aaaaa-bbbbb.hcp.eastus.azmk8s.io:443
CoreDNS is running at https://aks-user-aks-aaaaa-bbbbb.hcp.eastus.azmk8s.io:443/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
Metrics-server is running at https://aks-user-aks-aaaaa-bbbbb.hcp.eastus.azmk8s.io:443/api/v1/namespaces/kube-system/services/https:metrics-server:/proxy
~$ az aks list
"count": 1,
~$ kubectl get node
NAME STATUS ROLES AGE VERSION
aks-nodepool1-31246187-vmss000000 Ready agent 11m v1.28.9
Clean up
Always clean AKS resources that are no longer necessary - they could be costly!
To clean the AKS cluster, resources and juju cloud, run the following commands:
juju destroy-controller aks --destroy-all-models --destroy-storage --force
List all services and then delete those that have an associated EXTERNAL-IP value (load balancers, …):
kubectl get svc --all-namespaces
kubectl delete svc <service-name>
Next, delete the AKS resources (source: Deleting an all Azure VMs)
az aks delete -g aks -n ${JUJU_NAME}
Finally, logout from AKS to clean the local credentials (to avoid forgetting and leaking):
az logout
