Charmed PostgreSQL K8s
- Canonical
14/stable | 445 | 12 Nov 2024 | |
14/stable | 444 | 12 Nov 2024 | |
14/candidate | 463 | 19 Nov 2024 | |
14/candidate | 462 | 19 Nov 2024 | |
14/beta | 463 | 19 Nov 2024 | |
14/beta | 462 | 19 Nov 2024 | |
14/edge | 465 | 20 Nov 2024 | |
14/edge | 464 | 20 Nov 2024 |
Reference > Release Notes > All revisions > Revision 444/445
Revision 444/445 (hotfix for 381/382)
12 November 2024
Dear community,
Canonical has released a hotfix for Charmed PostgreSQL K8s operator in the 14/stable channel:
- Revision 444 is built for
amd64
on Ubuntu 22.04 LTS (postgresql-image r162) - Revision 445 is built for
arm64
Highlights
This is a hotfix release to add Juju 3.6 compatibility for the previous stable revisions 381/382.
Bugfixes and stability
- Fixed Juju 3.6 support - fixed Pebble 1.12+ compatibility (DPE-5915)
Known limitations
See the Release Notes for Revisions 381/382.
