postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 559 15 Apr 2025
14/candidate 558 15 Apr 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 565 18 Apr 2025
14/edge 564 18 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 563 17 Apr 2025
Ubuntu 24.04
16/edge 562 17 Apr 2025
Ubuntu 24.04
Charmed PostgreSQL K8s Tutorial > 4. Scale replicas
Scale your replicas
The Charmed PostgreSQL K8s operator uses a PostgreSQL Patroni-based cluster for scaling. It provides features such as automatic membership management, fault tolerance, and automatic failover. The charm uses PostgreSQL’s synchronous replication with Patroni.
In this section, you will learn to scale your Charmed PostgreSQL by adding or removing units (replicas).
This tutorial hosts all replicas on the same machine. This should not be done in a production environment.
To enable high availability in a production environment, replicas should be hosted on different servers to maintain isolation.
Add units
Currently, your deployment has only one juju unit, known in juju as the leader unit. You can think of this as the database primary instance. For each replica, a new unit is created. All units are members of the same database cluster.
To add two replicas to your deployed PostgreSQL application, use juju scale-application to scale it to three units:
juju scale-application postgresql-k8s 3
Note: Unlike machine models, Kubernetes models use juju scale-application instead of juju add-unit and juju remove-unit. For more information about juju’s scaling logic for kubernetes, check this post.
You can now watch the scaling process in live using: juju status --watch 1s. It usually takes several minutes for new cluster members to be added.
You’ll know that all three nodes are in sync when juju status reports Workload=active and Agent=idle:
tutorial  charm-dev   microk8s/localhost  2.9.42   unsupported  12:09:49+01:00
App             Version  Status  Scale  Charm           Channel    Rev  Address         Exposed  Message
postgresql-k8s           active      3  postgresql-k8s  14/stable  56   10.152.183.167  no
Unit               Workload  Agent  Address       Ports  Message
postgresql-k8s/0*  active    idle   10.1.188.206         Primary
postgresql-k8s/1   active    idle   10.1.188.209
postgresql-k8s/2   active    idle   10.1.188.210
Remove units
Removing a unit from the application scales down the replicas.
Before we scale them down, list all the units with juju status. You will see three units: postgresql-k8s/0, postgresql-k8s/1, and postgresql-k8s/2. Each of these units hosts a PostgreSQL replica.
To scale the application down to two units, enter:
juju scale-application postgresql-k8s 2
You’ll know that the replica was successfully removed when juju status --watch 1s reports:
tutorial  charm-dev   microk8s/localhost  2.9.42   unsupported  12:10:08+01:00
postgresql-k8s           active      2  postgresql-k8s  14/stable  56   10.152.183.167  no
Next step: 5. Manage passwords
Help improve this document in the forum (guidelines). Last updated 11 months ago.
