postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 559 15 Apr 2025
14/candidate 558 15 Apr 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 565 18 Apr 2025
14/edge 564 18 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 563 17 Apr 2025
Ubuntu 24.04
16/edge 562 17 Apr 2025
Ubuntu 24.04
Charmed PostgreSQL Tutorial > 1. Set up the environment
In this page, we will set up a development environment with the required components for deploying Charmed PostgreSQL K8s.
Before we start, make sure your machine meets the minimum system requirements.
Set up Multipass
Multipass is a quick and easy way to launch virtual machines running Ubuntu. It uses the cloud-init standard to install and configure all the necessary parts automatically.
Install Multipass from Snap:
sudo snap install multipass
Launch a new VM using the charm-dev cloud-init config:
multipass launch --cpus 4 --memory 8G --disk 50G --name my-vm charm-dev
To show all running VMs, just run the command multipass list. For more information about Multipass commands, see the Multipass CLI documentation.
As soon as a new VM has started, access it with:
multipass shell my-vm
Note: If at any point you’d like to leave a Multipass VM, enter Ctrl+D or type exit.
All necessary components have been pre-installed inside the VM already, like MicroK8s and Juju.
The files /var/log/cloud-init.log and /var/log/cloud-init-output.log contain all low-level installation details.
Set up Juju
Let’s bootstrap Juju to use the local MicroK8s controller. We will call it “overlord”, but you can give it any name you’d like.
juju bootstrap microk8s overlord
A controller can work with different models. Set up a specific model for Charmed PostgreSQL K8s named ‘tutorial’:
juju add-model tutorial
You can now view the model you created above by running the command juju status. You should see something similar to the following example output:
tutorial  overlord    microk8s/localhost  3.1.7    unsupported  11:56:38+01:00
Model "admin/tutorial" is empty.
Next step: 2. Deploy PostgreSQL
