postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 559 15 Apr 2025
14/candidate 558 15 Apr 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 565 Yesterday
14/edge 564 Yesterday
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 563 17 Apr 2025
Ubuntu 24.04
16/edge 562 17 Apr 2025
Ubuntu 24.04
Deploy on multiple availability zones (AZ)
During the deployment to Kubernetes, it is important to spread all the database copies (K8s pods/Juju units) to different hardware servers, or even better, to the different cloud availability zones (AZ). This will guarantee no shared service-critical components across the DB cluster (eliminate the case with all eggs in the same basket).
This guide will take you through deploying a PostgreSQL cluster on GKE using 3 available zones. All pods will be set up to sit in their dedicated zones only, which effectively guarantees database copy survival across all available AZs.
This documentation assumes that your cloud supports and provides availability zones concepts such as the K8s label topology.kubernetes.io/zone. This is enabled by default on EKS/GKE/AKS and supported by MicroK8s/Charmed Kubernetes.
See the Additional resources section for more details about AZ on specific clouds.
Set up Kubernetes on Google Cloud
Let’s deploy the PostgreSQL Cluster on GKE (us-east4) using all 3 zones there (us-east4-a, us-east4-b, us-east4-c) and make sure all pods always sits in the dedicated zones only.
Warning: Creating the following GKE resources may cost you money - be sure to monitor your GCloud costs.
Log into Google Cloud and bootstrap nine nodes of managed K8s on GCloud:
gcloud auth login
gcloud container clusters create --zone us-east4 $USER-$RANDOM --cluster-version 1.29.8 --machine-type n1-standard-4 --num-nodes=2 --total-max-nodes=2 --no-enable-autoupgrade
kubectl config get-contexts
/snap/juju/current/bin/juju add-k8s gke --client --context-name=$(kubectl config get-contexts | grep gke | awk '{print $2}')
juju bootstrap gke gke
juju add-model mymodel
Each node is equally grouped across availability zones (three K8s nodes in each AZ). You can check them with the following kubectl commands:
kubectl get nodes
> NAME                                          STATUS   ROLES    AGE     VERSION
> gke-default-pool-5c034921-fmtj   Ready    <none>   3h56m   v1.29.8-gke.1278000
> gke-default-pool-5c034921-t1sx   Ready    <none>   3h56m   v1.29.8-gke.1278000
> gke-default-pool-5c034921-zkzm   Ready    <none>   3h56m   v1.29.8-gke.1278000
> gke-default-pool-b33634ac-l0c9   Ready    <none>   3h56m   v1.29.8-gke.1278000
> gke-default-pool-b33634ac-phjx   Ready    <none>   3h56m   v1.29.8-gke.1278000
> gke-default-pool-b33634ac-w2jv   Ready    <none>   3h56m   v1.29.8-gke.1278000
> gke-default-pool-d196956a-0zfc   Ready    <none>   3h56m   v1.29.8-gke.1278000
> gke-default-pool-d196956a-591j   Ready    <none>   3h56m   v1.29.8-gke.1278000
> gke-default-pool-d196956a-zm6h   Ready    <none>   3h56m   v1.29.8-gke.1278000
kubectl get nodes --show-labels | awk 'NR == 1 {next} {print $1,$2,$6}' | awk -F "[ /]" '{print $1" \t"$NF" \t"$2}'
gke-default-pool-5c034921-fmtj     zone=us-east4-b         Ready
gke-default-pool-5c034921-t1sx     zone=us-east4-b         Ready
gke-default-pool-5c034921-zkzm     zone=us-east4-b         Ready
gke-default-pool-b33634ac-l0c9     zone=us-east4-c         Ready
gke-default-pool-b33634ac-phjx     zone=us-east4-c         Ready
gke-default-pool-b33634ac-w2jv     zone=us-east4-c         Ready
gke-default-pool-d196956a-0zfc     zone=us-east4-a         Ready
gke-default-pool-d196956a-591j     zone=us-east4-a         Ready
gke-default-pool-d196956a-zm6h     zone=us-east4-a         Ready
Deploy PostgreSQL with anti-affinity rules
Juju provides the support for affinity/anti-affinity rules using constraints. Read more about it in this forum post.
The command below demonstrates how to deploy Charmed PostgreSQL K8s with Juju constraints that create a pod anti-affinity rule:
export MYAPP="mydatabase" ; \
juju deploy postgresql-k8s ${MYAPP} --trust -n 3 \
 --constraints="tags=anti-pod.app.kubernetes.io/name=${MYAPP},anti-pod.topology-key=topology.kubernetes.io/zone"
This will effectively create a K8s pod anti-affinity rule. Check with the following command:
kubectl get pod mydatabase-0 -o yaml -n mymodel
spec:
  affinity:
    podAntiAffinity:
      requiredDuringSchedulingIgnoredDuringExecution:
      - labelSelector:
          matchExpressions:
          - key: app.kubernetes.io/name
            operator: In
            values:
            - mydatabase
        topologyKey: topology.kubernetes.io/zone
This example instructs the K8s scheduler to run K8s pods that match the Juju application name app.kubernetes.io/name: my database label on K8s nodes that have different values of topology.kubernetes.io/zone label. In other words, we asked to run all PostgreSQL instances in different Availability Zones, which is the common recommendation for any database deployment.
The selector and affinity/anti-affinity rules are extremely flexible and often require cloud-specific fine-tuning for your specific needs. The rule of thumb is to always check K8s node labels actually available in your environment and choose the appropriate label on your infrastructure.
The example below shows all available labels on GKE. You may want to run database instances on different virtual machines (kubernetes.io/hostname label) or in different Availability Zones (topology.kubernetes.io/zone label) :
kubectl get node gke-default-pool-b33634ac-l0c9 -o yaml
  labels:
    beta.kubernetes.io/arch: amd64
    beta.kubernetes.io/instance-type: n1-standard-4
    beta.kubernetes.io/os: linux
    cloud.google.com/gke-boot-disk: pd-balanced
    cloud.google.com/gke-container-runtime: containerd
    cloud.google.com/gke-cpu-scaling-level: "4"
    cloud.google.com/gke-logging-variant: DEFAULT
    cloud.google.com/gke-max-pods-per-node: "110"
    cloud.google.com/gke-nodepool: default-pool
    cloud.google.com/gke-os-distribution: cos
    cloud.google.com/gke-provisioning: standard
    cloud.google.com/gke-stack-type: IPV4
    cloud.google.com/machine-family: n1
    cloud.google.com/private-node: "false"
    failure-domain.beta.kubernetes.io/region: us-east4
    failure-domain.beta.kubernetes.io/zone: us-east4-c
    kubernetes.io/hostname: gke-default-pool-b33634ac-l0c9
    node.kubernetes.io/instance-type: n1-standard-4
    topology.gke.io/zone: us-east4-c
    topology.kubernetes.io/region: us-east4
    topology.kubernetes.io/zone: us-east4-c
After a successful deployment, juju status will show an active application:
Model    Controller  Cloud/Region  Version  SLA          Timestamp
mymodel  gke         gke/us-east4  3.5.3    unsupported  22:02:32+02:00
App         Version  Status  Scale  Charm           Channel    Rev  Address         Exposed  Message
mydatabase  14.13    active      3  postgresql-k8s  14/stable  382  34.118.235.169  no
Unit           Workload  Agent  Address    Ports  Message
mydatabase/0   active    idle   10.80.5.9
mydatabase/1*  active    idle   10.80.6.7         Primary
mydatabase/2   active    idle   10.80.1.6
and each pod will sit in the separate AZ out of the box:
kubectl get pods -n mymodel -o wide
> NAME             READY   STATUS    RESTARTS   AGE   IP          NODE
> mydatabase-0     2/2     Running   0          16m   10.80.5.7   gke-default-pool-b33634ac-l0c9  ... # us-east4-c
> mydatabase-1     2/2     Running   0          24m   10.80.6.7   gke-default-pool-d196956a-0zfc  ... # us-east4-a
> mydatabase-2     2/2     Running   0          24m   10.80.0.3   gke-default-pool-5c034921-zkzm  ... # us-east4-b
Simulation: A node gets drained
Let’s drain a node and make sure the rescheduled pod will stay the same AZ:
kubectl drain  --ignore-daemonsets --delete-emptydir-data  gke-default-pool-b33634ac-l0c9
> node/gke-default-pool-b33634ac-l0c9 cordoned
> evicting pod mymodel/mydatabase-0
> pod/mydatabase-0 evicted
> node/gke-default-pool-b33634ac-l0c9 drained
As we can see the newly rescheduled pod landed the new node in the same AZ us-east4-c:
> mydatabase-0     2/2     Running   0           1m   10.80.5.7   gke-default-pool-b33634ac-phjx  ... # us-east4-c
> mydatabase-1     2/2     Running   0          35m   10.80.6.7   gke-default-pool-d196956a-0zfc  ... # us-east4-a
> mydatabase-2     2/2     Running   0          35m   10.80.0.3   gke-default-pool-5c034921-zkzm  ... # us-east4-b
Simulation: All nodes get cordoned
In case we lose (cordon) all nodes in AZ, the pod will stay pending as K8s scheduler cannot find the proper node. Let’s simulate it:
kubectl drain  --ignore-daemonsets --delete-emptydir-data  gke-default-pool-b33634ac-phjx
kubectl drain  --ignore-daemonsets --delete-emptydir-data  gke-default-pool-b33634ac-w2jv
> gke-default-pool-b33634ac-l0c9     zone=us-east4-c         Ready,SchedulingDisabled
> gke-default-pool-b33634ac-phjx     zone=us-east4-c         Ready,SchedulingDisabled
> gke-default-pool-b33634ac-w2jv     zone=us-east4-c         Ready,SchedulingDisabled
> mydatabase-0               0/2     Pending   0          2m9s # Pending!!!
> mydatabase-1               2/2     Running   0          96m
> mydatabase-2               2/2     Running   0          51m
kubectl describe pod mydatabase-0 -n mymodel  | tail -10
> Events:
>   Type     Reason             Age    From                Message
>   Warning  FailedScheduling   3m32s  default-scheduler   0/9 nodes are available: 3 node(s) were unschedulable, 6 node(s) had volume node affinity conflict. preemption: 0/9 nodes are available: 9 Preemption is not helpful for scheduling.
>   Warning  FailedScheduling   3m30s  default-scheduler   0/9 nodes are available: 3 node(s) were unschedulable, 6 node(s) had volume node affinity conflict. preemption: 0/9 nodes are available: 9 Preemption is not helpful for scheduling.
>   Warning  FailedScheduling   3m27s  default-scheduler   0/9 nodes are available: 3 node(s) were unschedulable, 6 node(s) had volume node affinity conflict. preemption: 0/9 nodes are available: 9 Preemption is not helpful for scheduling.
>   Normal   NotTriggerScaleUp  3m33s  cluster-autoscaler  pod didn't trigger scale-up:
The juju status output will indicate this problem as well:
mymodel  gke         gke/us-east4  3.5.3    unsupported  22:31:00+02:00
mydatabase  14.13    waiting    2/3  postgresql-k8s  14/stable  382  34.118.235.169  no       installing agent
mydatabase/0   unknown   lost                     agent lost, see 'juju show-status-log mydatabase/0'
Let’s uncordon all nodes to keep the house clean:
kubectl uncordon gke-default-pool-b33634ac-l0c9
kubectl uncordon gke-default-pool-b33634ac-phjx
kubectl uncordon gke-default-pool-b33634ac-w2jv
The K8s scheduler will return the pod back to AZ us-east4-c and Juju will automatically rejoin the database unit back to the cluster:
mymodel  gke         gke/us-east4  3.5.3    unsupported  22:38:23+02:00
mydatabase/0   active    idle   10.80.5.10
At this point we can relax and enjoy the protection from Cloud Availability zones!
To survive acomplete cloud outage, we recommend setting up cluster-cluster asynchronous replication.
Remove GKE setup
Warning: Do not forget to remove your GKE test setup - it can be costly!
gcloud container clusters list
gcloud container clusters delete <gke_name> --location <gke_location>
juju unregister gke --no-prompt
juju remove-cloud gke
Below you will find specific information about AZs on specific clouds and more about node selection on Kubernetes.
Cloud-specific details about multiple availability zones
Kubernetes strategies to choose hardware nodes
