Charmed PostgreSQL K8s
- Canonical
14/edge | 547 | Yesterday | |
14/edge | 546 | Yesterday | |
16/edge | 543 | 26 Mar 2025 | |
16/edge | 542 | 26 Mar 2025 |
juju deploy postgresql-k8s --channel 14/stable
System Requirements
The following are the minimum software and hardware requirements to run Charmed PostgreSQL on K8s.
Software
- Ubuntu 22.04 LTS (Jammy) or later.
Juju
The charm supports several Juju releases from 2.9 LTS onwards. The table below shows which minor versions of each major Juju release are supported by Charmed PostgreSQL.
Juju major release | Supported minor versions | Compatible charm revisions | Comment |
3.6.1+ |
444/445+ | Recommended for production. | |
3.5.1+ |
280+ | Known Juju issue in 3.5.0 |
3.4.3+ |
280+ | Know Juju issues with previous minor versions | |
3.3.0+ |
from 177 to 193 | No known issues | |
3.2.0+ |
3.1.7+ |
from 177 to 193 | Juju secrets were stabilized in 3.1.7 |
2.9.49+ |
73+ | ||
2.9.32+ |
73 to 193 | No tests for older Juju versions. |
Kubernetes
- Kubernetes
1.27+
- Canonical MicroK8s
1.27+
(snap channel1.27-strict/stable
and newer)
Hardware
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required OCI/ROCKs and charms.
Supported architectures
The charm is based on the charmed-postgresql snap. It currently supports:
amd64
arm64
(from revision211+
The charm is based on the ROCK OCI named charmed-postgresql
Contact us if you are interested in new architectures!
Networking
At the moment IPv4 is supported only (see more info).
Contact us if you are interested in IPv6!
