PgBouncer K8s
- By Canonical Data Platform
1/stable | 103 | 08 Mar 2024 | |
1/candidate | 145 | 04 May 2024 | |
1/beta | 145 | 04 May 2024 | |
1/edge | 147 | 04 May 2024 |
PgBouncer K8s tutorial
The PgBouncer K8s Operator delivers automated operations management from day 0 to day 2 on the PgBouncer - the lightweight connection pooler for PostgreSQL. It is an open source, end-to-end, production-ready data platform on top of Juju.
As a first step, this tutorial will show you how to get PgBouncer K8s up and running. Then, you will learn a variety of operations such as adding replicas and enabling Transport Layer Security (TLS).
In this tutorial, we will walk through how to:
- Set up an environment using Multipass with MicroK8s and Juju.
- Deploy PgBouncer K8s using a single command.
- Configure TLS certificate in one command.
Requirements
While this tutorial intends to guide and teach you as you deploy PgBouncer K8s, it will be most beneficial if:
- You are familiar with basic terminal commands.
- You are familiar with basic PostgreSQL and PgBouncer concepts.
- You are familiar with Charmed PostgreSQL K8s
- Your machine fulfils the minimum requirements.
Step-by-step guide
Here’s an overview of the steps you will take in this tutorial:
- Set up the environment
- Deploy PgBouncer
- Managing your units
- Enable security
- Clean up your environment
