PgBouncer K8s
- By Canonical Data Platform
1/stable | 103 | 08 Mar 2024 | |
1/candidate | 145 | 04 May 2024 | |
1/beta | 145 | 04 May 2024 | |
1/edge | 147 | 04 May 2024 |
Major Rollback
Example: PgBouncer 2 -> PgBouncer 1
Currently, the charm supports PgBouncer major version 1 only; therefore, minor rollbacks are only possible. Canonical is NOT planning to support in-place rollbacks for the major PgBouncer version change as the old PostgreSQL cluster with the old PgBouncer installation will stay nearby and can be reused for the rollback.
