PgBouncer K8s
- By Canonical Data Platform
1/stable | 103 | 08 Mar 2024 | |
1/candidate | 145 | 04 May 2024 | |
1/beta | 145 | 04 May 2024 | |
1/edge | 147 | 04 May 2024 |
How to enable monitoring
Enable monitoring requires that you:
- Have a PgBouncer K8s deployed
- Deploy
cos-lite
bundle in a Kubernetes environment - COS configured for Charmed PostgreSQL K8s
Switch to COS K8s environment and offer COS interfaces to be cross-model related with PgBouncer K8s model:
# Switch to Kubernetes controller, for the cos model.
juju switch <k8s_cos_controller>:<cos_model_name>
juju offer grafana:grafana-dashboard
juju offer loki:logging
juju offer prometheus:receive-remote-write
Switch to PgBouncer K8s model, find offers and consume them:
# We are on the Kubernetes controller, for the cos model. Switch to postgresql model
juju switch <k8s_db_controller>:<postgresql_model_name>
juju find-offers <k8s_cos_controller>: # Do not miss ':' here!
A similar output should appear, if k8s
is the k8s controller name and cos
the model where cos-lite
has been deployed:
Store URL Access Interfaces
k8s admin/cos:grafana admin grafana:grafana-dashboard
k8s admin/cos.loki admin loki:logging
k8s admin/cos.prometheus admin prometheus:receive-remote-write
Consume offers to be reachable in the current model:
juju consume <k8s_cos_controller>:admin/cos.grafana
juju consume <k8s_cos_controller>:admin/cos.loki
juju consume <k8s_cos_controller>:admin/cos.prometheus
Now, deploy ‘grafana-agent-k8s’ (as pgbouncer-cos-agent
) and integrate (relate) it with PgBouncer K8s, later integrate (relate) pgbouncer-cos-agent
with consumed COS offers:
juju deploy grafana-agent-k8s pgbouncer-cos-agent --trust
juju relate pgbouncer-cos-agent grafana
juju relate pgbouncer-cos-agent loki
juju relate pgbouncer-cos-agent prometheus
juju relate pgbouncer-cos-agent pgbouncer-k8s:grafana-dashboard
juju relate pgbouncer-cos-agent pgbouncer-k8s:logging
juju relate pgbouncer-cos-agent pgbouncer-k8s:metrics-endpoint
After this is complete, Grafana will show the new dashboards: PgBouncer Exporter
and allows access for PgBouncer logs on Loki.
The example of juju status
for Charmed PostgreSQL K8s + PgBouncer K8s model:
TODO
on COS K8s model:
cos microk8s microk8s/localhost 3.1.6 unsupported 00:21:19+02:00
alertmanager 0.25.0 active 1 alertmanager-k8s edge 91 10.152.183.215 no
catalogue active 1 catalogue-k8s edge 27 10.152.183.187 no
grafana 9.2.1 active 1 grafana-k8s edge 92 10.152.183.95 no
loki 2.7.4 active 1 loki-k8s edge 99 10.152.183.28 no
prometheus 2.46.0 active 1 prometheus-k8s edge 149 10.152.183.232 no
traefik 2.10.4 active 1 traefik-k8s edge 155 10.76.203.228 no
alertmanager/0* active idle 10.1.142.186
catalogue/0* active idle 10.1.142.176
grafana/0* active idle 10.1.142.189
loki/0* active idle 10.1.142.187
prometheus/0* active idle 10.1.142.188
traefik/0* active idle 10.1.142.185
Offer Application Charm Rev Connected Endpoint Interface Role
grafana grafana grafana-k8s 92 1/1 grafana-dashboard grafana_dashboard requirer
loki loki loki-k8s 99 1/1 logging loki_push_api provider
prometheus prometheus prometheus-k8s 149 1/1 receive-remote-write prometheus_remote_write provider
To connect Grafana WEB interface, follow the COS section “Browse dashboards”:
juju run grafana/leader get-admin-password --model <k8s_cos_controller>:<cos_model_name>
