PgBouncer K8s
- By Canonical Data Platform
1/stable | 103 | 08 Mar 2024 | |
1/candidate | 145 | 04 May 2024 | |
1/beta | 145 | 04 May 2024 | |
1/edge | 147 | 04 May 2024 |
Minor Rollback
Example: PgBouncer 1.19 -> PgBouncer 1.18
(including simple charm revision bump: from revision 43 to revision 42)
WARNING: do NOT trigger
rollback
during the runningupgrade
action! It may cause unpredictable PostgreSQL Cluster and/or PgBouncer state!
Minor rollback steps
The rollback is NOT necessary if sacrificial unit
is created before the upgrade, just remove it using scale-down the application. Otherwise perform the rollback:
Rollback. Perform the charm rollback using
juju refresh
. The unit with the maximal ordinal will be rolled-back first and rollback continues for entire application. - Check. Make sure the charm and cluster are in healthy state again.
Manual Rollback
After a juju refresh
, case there any version incompatibilities in charm revisions or it dependencies, or any other unexpected failure in the upgrade process, the upgrade process will be halted an enter a failure state.
Although the underlying PostgreSQL Cluster and PgBouncer continue to work, it’s important to rollback the charm to previous revision so an update can be later attempted after a further inspection of the failure.
To execute a rollback we take the same procedure as the upgrade, the difference being the charm revision to upgrade to. In case of this tutorial example, one would refresh the charm back to revision 88
, the steps being:
Step 1: Rollback
When using charm from charmhub:
juju refresh pgbouncer-k8s --revision=88 --trust
Case deploying from local charm file, one need to have the previous revision charm file and the postgresql-image
resource, then run:
juju refresh pgbouncer-k8s --trust --path=./pgbouncer-k8s_ubuntu-22.04-amd64.charm \
--resource pgbouncer-image=ghcr.io/canonical/charmed-postgresql@sha256:753477ce39712221f008955b746fcf01a215785a215fe3de56f525380d14ad97
Where pgbouncer-k8s_ubuntu-22.04-amd64.charm
is the previous revision charm file. The reference for the resource for a given revision can be found at the metadata.yaml
file in the charm repository.
The biggest ordinal unit will be rolled out and should rejoin the cluster after settling down. After the refresh command, the juju controller revision for the application will be back in sync with the running PgBouncer K8s revision.
Step 2: Check
The future improvement is planned to check the state on pod/cluster on a low level. At the moment check juju status
to make sure the cluster state is OK.
