PgBouncer K8s
- By Canonical Data Platform
1/stable | 103 | 08 Mar 2024 | |
1/candidate | 145 | 04 May 2024 | |
1/beta | 145 | 04 May 2024 | |
1/edge | 147 | 04 May 2024 |
Juju version
The charm supports both Juju 2.9 LTS and Juju 3.1.
The minimum supported Juju versions are:
- 2.9.32+
- 3.1.7+ (Juju secrets refactored/stabilized in Juju 3.1.7)
Kubernetes requirements
- Kubernetes 1.27+
- Canonical MicroK8s 1.27+ (snap channel 1.27-strict/stable and newer)
Minimum requirements
Make sure your machine meets the following requirements:
- Ubuntu 22.04 (Jammy) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required OCI/ROCKs and charms.
Supported architectures
The charm is based on ROCK OCI named “charmed-postgresql”, which is recursively based on SNAP “charmed-postgresql”, which is currently available for amd64
and arm64
(revision 146+). Please contact us if you are interested in new architecture!
Charmed PostgreSQL K8s requirements
Please also keep in mind “Charmed PostgreSQL K8s” requirements.
