PgBouncer K8s
- By Canonical Data Platform
1/stable | 103 | 08 Mar 2024 | |
1/candidate | 145 | 04 May 2024 | |
1/beta | 145 | 04 May 2024 | |
1/edge | 147 | 04 May 2024 |
Interfaces/endpoints
PgBouncer K8s supports modern ‘postgresql_client’ interface. Applications can easily connect PgBouncer using ‘data_interfaces’ library from ‘data-platform-libs’.
Modern postgresql_client
interface (database
endpoint):
Adding a relation is accomplished with juju relate
(or juju integrate
for Juju 3.x) via endpoint database
. Read more about Juju relations (integrations). Example:
# Deploy Charmed PostgreSQL K8s and PgBouncer K8s clusters with 3 nodes each
juju deploy postgresql-k8s -n 3 --trust --channel 14/stable
juju deploy pgbouncer-k8s -n 3 --trust --channel 1/stable
# Deploy the relevant charms, e.g. postgresql-test-app
juju deploy postgresql-test-app
# Relate all applications
juju integrate postgresql-k8s pgbouncer-k8s
juju integrate pgbouncer-k8s postgresql-test-app:first-database
# Check established relation (using postgresql_client interface):
juju status --relations
# Example of the properly established relation:
# > Integration provider Requirer Interface Type Message
# > pgbouncer-k8s:database postgresql-test-app:first-database postgresql_client regular
# > postgresql-k8s:database pgbouncer-k8s:backend-database postgresql_client regular
See all the charm interfaces here.
