PgBouncer K8s
- By Canonical Data Platform
1/stable | 103 | 08 Mar 2024 | |
1/candidate | 145 | 04 May 2024 | |
1/beta | 145 | 04 May 2024 | |
1/edge | 147 | 04 May 2024 |
Deploy PgBouncer K8s
Please follow the PgBouncer K8s Tutorial for technical details and explanations.
Short story for your Ubuntu 22.04 LTS:
sudo snap install multipass
multipass launch --cpus 4 --memory 8G --disk 30G --name my-vm charm-dev # tune CPU/RAM/HDD accordingly to your needs
multipass shell my-vm
juju add-model demo
juju deploy postgresql-k8s --channel 14/stable --trust # --config profile=testing
juju deploy pgbouncer-k8s --channel 1/stable --trust
juju integrate postgresql-k8s pgbouncer-k8s
juju status --watch 1s
The expected result:
demo microk8s microk8s/localhost 3.1.6 unsupported 22:42:26+02:00
pgbouncer-k8s 1.18.0 active 1 pgbouncer-k8s 1/stable 76 10.152.183.128 no backend-database relation initialised.
postgresql-k8s 14.9 active 1 postgresql-k8s 14/stable 158 10.152.183.110 no
pgbouncer-k8s/0* active executing 10.1.12.36 backend-database relation initialised.
postgresql-k8s/0* active idle 10.1.12.22
The charm PgBouncer K8s is now waiting for relations with a client application, e.g. postgresql-test-app, mattermost, …
Check the Testing reference to test your deployment.
