PgBouncer K8s
- By Canonical Data Platform
1/stable | 103 | 08 Mar 2024 | |
1/candidate | 145 | 04 May 2024 | |
1/beta | 145 | 04 May 2024 | |
1/edge | 147 | 04 May 2024 |
PgBouncer K8s revision 76
Monday, October 23, 2023
Dear community, we would like to inform you that new PgBouncer K8s is published in the 1/stable
charmhub channel for Kubernetes.
Features you can start using today:
- Added Juju 3 support (Juju 2 is still supported) [DPE-1762]
- Juju peer and relation secrets support [DPE-1766][DPE-2296]
- Charm minor upgrades and minor rollbacks [DPE-1771]
- “Charmed PostgreSQL K8s” extensions support [DPE-2056]
- COS support [DPE-1779]
- Logs rotation [DPE-1756]
- TLS support [DPE-335]
- The “data-integrator” support
- Support for modern
postgresql_client
, legacypgsql
andtls-certificates
interfaces - Workload updated to PgBouncer 1.18 (fixes for PostgreSQL 14)
- Complete documentation on CharmHub
Bugfixes included:
GitHub Releases provides a detailed list of bugfixes/PRs/commits for each revision.
What is inside the charms:
- Charmed PgBouncer K8s ships the latest PgBouncer “1.18.0-0ubuntu0.22.04.1”
- The Prometheus pgbouncer-exporter is “0.7.0-0ubuntu0.22.04.1~ppa1”
- K8s charms based on our ROCK OCI (Ubuntu LTS “22.04” - ubuntu:22.04-based)
Technical notes:
- Upgrade (
juju refresh
) is possible from this revision 76+. - Please check the external components requirements
- Use this operator together with modern Charmed PostgreSQL K8s operator.
How to reach us:
Contribute to the project!
Footer:
It is the first stable release of the operator “PgBouncer K8s” by Canonical Data.
Well done, Team!
