Charmed MySQL K8s
- By Canonical Data Platform
Manage Passwords
This is part of the Charmed MySQL Tutorial. Please refer to this page for more information and the overview of the content.
Passwords
When we accessed MySQL earlier in this tutorial, we needed to use a password manually. Passwords help to secure our database and are essential for security. Over time it is a good practice to change the password frequently. Here we will go through setting and changing the password for the admin user.
Retrieve the root password
As previously mentioned, the root password can be retrieved by running the get-password
action on the Charmed MySQL K8s application:
juju run-action mysql-k8s/leader get-password --wait
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results:
password: sQI3Ojih7uL5UC4J1D9Xuqgx
username: root
status: completed
timing:
completed: 2023-02-15 21:51:04 +0000 UTC
enqueued: 2023-02-15 21:50:59 +0000 UTC
started: 2023-02-15 21:51:04 +0000 UTC
Rotate the root password
You can change the root password to a new random password by entering:
juju run-action mysql-k8s/leader set-password --wait
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results: {}
status: completed
timing:
completed: 2023-02-15 21:51:37 +0000 UTC
enqueued: 2023-02-15 21:51:34 +0000 UTC
started: 2023-02-15 21:51:37 +0000 UTC
Please notice the status: completed
above which means the password has been successfully updated. To be sure, please call get-password
once again:
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results:
password: sN6bcP1j7xRfhw4ZDblcIYK1
username: root
status: completed
timing:
completed: 2023-02-15 21:52:13 +0000 UTC
enqueued: 2023-02-15 21:52:11 +0000 UTC
started: 2023-02-15 21:52:12 +0000 UTC
The root password should be different from the previous password.
Set the root password
You can change the root password to a specific password by entering:
juju run-action mysql-k8s/leader set-password password=my-password --wait && \
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results: {}
status: completed
timing:
completed: 2023-02-15 21:52:47 +0000 UTC
enqueued: 2023-02-15 21:52:45 +0000 UTC
started: 2023-02-15 21:52:46 +0000 UTC
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results:
password: my-password
username: root
status: completed
timing:
completed: 2023-02-15 21:52:48 +0000 UTC
enqueued: 2023-02-15 21:52:47 +0000 UTC
started: 2023-02-15 21:52:47 +0000 UTC
The root password
should match whatever you passed in when you entered the command.
