Charmed MySQL K8s
- By Canonical Data Platform
Deploy Charmed MySQL K8s on EKS
Amazon Elastic Kubernetes Service (EKS) - one of the most popular and fully automated Kubernetes service from Amazon. To access EKS WEB interface, open the Console https://console.aws.amazon.com/eks/home
Install EKS and Juju tooling
Install:
- Juju (an open source orchestration engine from Canonical)
- kubectl (Kubernetes command line tool)
- eksctl (the official CLI for Amazon EKS)
- AWC CLI (Amazon Web Services Command Line Interface)
Make sure all works:
> juju version
2.9.45-ubuntu-amd64
> kubectl version --client
Client Version: v1.28.2
Kustomize Version: v5.0.4-0.20230601165947-6ce0bf390ce3
> eksctl info
eksctl version: 0.159.0
kubectl version: v1.28.2
> aws --version
aws-cli/2.13.25 Python/3.11.5 Linux/6.2.0-33-generic exe/x86_64.ubuntu.23 prompt/off
Create IAM account (or legacy Access keys) and login to AWS:
> aws configure
AWS Access Key ID [None]: SECRET_ACCESS_KEY_ID
AWS Secret Access Key [None]: SECRET_ACCESS_KEY_VALUE
Default region name [None]: eu-west-3
Default output format [None]:
> aws sts get-caller-identity
"UserId": "1234567890",
"Account": "1234567890",
"Arn": "arn:aws:iam::1234567890:root"
Bootstrap Kubernetes cluster (EKS)
Export the deployment name to be used further:
export JUJU_NAME=eks-$USER-$RANDOM
Feel free to fine-tune the location (eu-west-3
) and/or K8s version (1.27
cat <<-EOF > cluster.yaml
apiVersion: eksctl.io/v1alpha5
kind: ClusterConfig
metadata:
region: eu-west-3
version: "1.27"
iam:
withOIDC: true
addons:
- name: aws-ebs-csi-driver
wellKnownPolicies:
ebsCSIController: true
nodeGroups:
- name: ng-1
minSize: 3
maxSize: 5
iam:
attachPolicyARNs:
- arn:aws:iam::aws:policy/AmazonEKSWorkerNodePolicy
- arn:aws:iam::aws:policy/AmazonEKS_CNI_Policy
- arn:aws:iam::aws:policy/AmazonEC2ContainerRegistryReadOnly
- arn:aws:iam::aws:policy/AmazonSSMManagedInstanceCore
- arn:aws:iam::aws:policy/AmazonS3FullAccess
instancesDistribution:
maxPrice: 0.15
instanceTypes: ["m5.xlarge", "m5.2xlarge"] # At least two instance types should be specified
onDemandBaseCapacity: 0
onDemandPercentageAboveBaseCapacity: 50
spotInstancePools: 2
EOF
Bootstrap EKS cluster:
> eksctl create cluster -f cluster.yaml
2023-10-12 11:13:58 [ℹ] using region eu-west-3
2023-10-12 11:13:59 [ℹ] using Kubernetes version 1.27
2023-10-12 11:40:00 [✔] EKS cluster "eks-taurus-27506" in "eu-west-3" region is ready
Bootstrap Juju on EKS
TIP: Juju 3.x Bug #2007848 “Unable to bootstrap EKS cluster to Juju 3.1” : Bugs : Canonical Juju
# Add Juju K8s Clous
> juju add-k8s $JUJU_NAME
# Bootstrap Juju Controller
> juju bootstrap $JUJU_NAME
# Create a new Juju model (K8s namespace)
> juju add-model welcome
# (optional) Increase DEBUG level if you are troubleshooting charms
> juju model-config logging-config='<root>=INFO;unit=DEBUG'
Deploy Charms
> juju deploy mysql-k8s-bundle --channel 8.0/edge --trust
> juju deploy mysql-test-app
> juju relate mysql-test-app mysql-k8s:database
> juju status --watch 1s
List
> juju controllers
Controller Model User Access Cloud/Region Models Nodes HA Version
eks-taurus-27506* welcome admin superuser eks-taurus-27506 2 1 - 2.9.45
> kubectl cluster-info
Kubernetes control plane is running at https://AAAAAAAAAAAAAAAAAAAAAAA.gr7.eu-west-3.eks.amazonaws.com
CoreDNS is running at https://AAAAAAAAAAAAAAAAAAAAAAA.gr7.eu-west-3.eks.amazonaws.com/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
> eksctl get cluster -A
NAME REGION EKSCTL CREATED
eks-taurus-27506 eu-west-3 True
> kubectl get node
NAME STATUS ROLES AGE VERSION
ip-192-168-14-61.eu-west-3.compute.internal Ready <none> 19m v1.27.5-eks-43840fb
ip-192-168-51-96.eu-west-3.compute.internal Ready <none> 19m v1.27.5-eks-43840fb
ip-192-168-78-167.eu-west-3.compute.internal Ready <none> 19m v1.27.5-eks-43840fb
Cleanup
Note: always clean no-longer necessary EKS resources as they all could be costly!!!
To clean EKS cluster, resources and juju cloud, use:
> juju destroy-controller $JUJU_NAME --yes --destroy-all-models --destroy-storage --force
> juju remove-cloud $JUJU_NAME
> kubectl get svc --all-namespaces
> kubectl delete svc <service-name> # Delete any services that have an associated EXTERNAL-IP value (load balancers, ...)
> eksctl delete cluster <cluster_name> --region eu-west-3 --force --disable-nodegroup-eviction
Remove AWS CLI user credentials (to avoid forgetting and leaking):
> rm -f ~/.aws/credentials
