Charmed MySQL K8s
- By Canonical Data Platform
Charm lifecycle flowcharts
Click to navigate the mermaid diagram on GitHub.
flowchart TD
id101([leader_elected]) --> id102[generate\npassword/configs]
id102 --> id103[store peer databag]
id103 --> id104((return))
id201([pebble_ready]) --> id202{if not `configured` \nnor peer relation}
id202 --> id203>defer]
id202 -- else --> id204[add pebble layer]
id204 --> id205[configure mysql\nusers]
id205 --> id206[configure instance\nfor GR]
id206 --> id207{is leader?}
id207 -- no --> id208((return))
id207 -- yes --> id209[create GR cluster]
id209 --> id208
id301([peer_relation_changed\nor\nupdate_status]) --> id302{is waiting\nto join}
id302 -- yes --> id303{is already\nin cluster?}
id303 --> id304[get primary\nfrom any online peer]
id304 --> id305[get current\ncluster node count]
id305 --> id306{is cluster\nat max size}
id306 -- no --> id307{is cluster\ntopology\nchanging}
id307 --> id309[acquire topology\nchange token]
id309 --> id310[join the cluster\nfrom primary]
id310 --> id311[release token]
id306 -- yes --> id308[Set blocked\nand standby]
id302 -- no --> id399((return))
id303 -- yes --> id399
id307 --> id399
id308 --> id399
id311 --> id399
