Charmed MySQL K8s
- By Canonical Data Platform
Integrating your Charmed MySQL
This is part of the Charmed MySQL Tutorial. Please refer to this page for more information and the overview of the content.
Integrations (Relations for Juju 2.9)
Relations, or what Juju 3.0+ documentation describes as an Integration, are the easiest way to create a user for MySQL in Charmed MySQL K8s. Relations automatically create a username, password, and database for the desired user/application. As mentioned earlier in the Access MySQL section it is a better practice to connect to MySQL via a specific user rather than the admin user.
Data Integrator Charm
Before relating to a charmed application, we must first deploy our charmed application. In this tutorial we will relate to the Data Integrator Charm. This is a bare-bones charm that allows for central management of database users, providing support for different kinds of data platforms (e.g. MySQL, PostgreSQL, MongoDB, Kafka, etc) with a consistent, opinionated and robust user experience. In order to deploy the Data Integrator Charm we can use the command juju deploy
we have learned above:
juju deploy data-integrator --channel edge --config database-name=test-database
The expected output:
Located charm "data-integrator" in charm-hub, revision 4
Deploying "data-integrator" from charm-hub charm "data-integrator", revision 4 in channel edge on jammy
Checking the deployment progress using juju status
will show you the blocked
state for newly deployed charm:
tutorial overlord microk8s/localhost 2.9.38 unsupported 22:54:31+01:00
data-integrator waiting 1 data-integrator edge 4 10.152.183.180 no installing agent
mysql-k8s 8.0.31 active 2 mysql-k8s 8.0/stable 36 10.152.183.234 no
data-integrator/0* blocked idle 10.1.84.66 Please relate the data-integrator with the desired product
mysql-k8s/0* active idle 10.1.84.74 Unit is ready: Mode: RW
mysql-k8s/1 active idle 10.1.84.127 Unit is ready: Mode: RO
The blocked
state is expected due to not-yet established relation (integration) between applications.
Relate to MySQL
Now that the Database Integrator Charm has been set up, we can relate it to MySQL. This will automatically create a username, password, and database for the Database Integrator Charm. Relate the two applications with:
juju relate data-integrator mysql-k8s
Wait for juju status --watch 1s
to show all applications/units as active
tutorial overlord microk8s/localhost 2.9.38 unsupported 22:55:44+01:00
data-integrator/0* active idle 10.1.84.66
To retrieve information such as the username, password, and database. Enter:
juju run-action data-integrator/leader get-credentials --wait
This should output something like:
unit-data-integrator-0:
UnitId: data-integrator/0
results:
mysql:
endpoints: mysql-k8s-0.mysql-k8s-endpoints:3306
password: 7VRfmGjfUI1pVUPsfbMwmHFm
read-only-endpoints: mysql-k8s-0.mysql-k8s-endpoints:3306,mysql-k8s-1.mysql-k8s-endpoints:3306
username: relation-3
version: 8.0.31-0ubuntu0.22.04.1
ok: "True"
status: completed
timing:
completed: 2023-02-15 21:56:22 +0000 UTC
enqueued: 2023-02-15 21:56:17 +0000 UTC
started: 2023-02-15 21:56:21 +0000 UTC
Note: your hostnames, usernames, and passwords will likely be different.
Access the related database
Use endpoints
, username
, password
from above to connect newly created database test-database
on MySQL K8s server:
> mysql -h 10.1.84.74 -u relation-3 -p7VRfmGjfUI1pVUPsfbMwmHFm -e "show databases;"
| Database |
| information_schema |
| performance_schema |
| test-database |
The newly created database test-database
is also available on all other MySQL K8s cluster members:
> mysql -h 10.1.84.127 -u relation-3 -p7VRfmGjfUI1pVUPsfbMwmHFm -e "show databases;"
| Database |
| test-database |
When you relate two applications Charmed MySQL K8s automatically sets up a new user and database for you.
Please note the database name we specified when we first deployed the data-integrator
charm: --config database-name=test-database
Remove the user
To remove the user, remove the relation. Removing the relation automatically removes the user that was created when the relation was created. Enter the following to remove the relation:
juju remove-relation mysql-k8s data-integrator
Now try again to connect to the same MySQL K8s you just used in Access the related database:
This will output an error message:
ERROR 1045 (28000): Access denied for user 'relation-3'@'10.76.203.127' (using password: YES)
As this user no longer exists. This is expected as juju remove-relation mysql-k8s data-integrator
also removes the user.
Note: data stay remain on the server at this stage!
Relate the the two applications again if you wanted to recreate the user:
Re-relating generates a new user and password:
You can connect to the database with this new credentials. From here you will see all of your data is still present in the database.
