Charmed MySQL K8s
- By Canonical Data Platform
Clients for Async replication
WARNING: it is an internal article. Do NOT use it in production! Contact Canonical Data Platform team if you are interested in the topic.
Pre-requisits
Make sure both Rome
and Lisbon
Clusters are deployed using the Async Deployment manual!
Offer and consume DB endpoints
juju switch rome
juju offer db1:database db1-database
juju switch lisbon
juju offer db2:database db2-database
juju add-model app ; juju switch app
juju consume rome.db1-database
juju consume lisbon.db2-database
Internal Juju app/clients
juju switch app
juju deploy mysql-test-app
juju deploy mysql-router-k8s --trust --channel 8.0/edge
juju relate mysql-test-app mysql-router-k8s
juju relate mysql-router-k8s db1-database
External Juju clients
juju switch app
juju deploy data-integrator --config database-name=mydatabase
juju deploy mysql-router-k8s mysql-router-external --trust --channel 8.0/edge
juju relate data-integrator mysql-router-external
juju relate mysql-router-external db1-database
