Charmed MySQL K8s
- By Canonical Data Platform
Deploy Charmed MySQL K8s
Please follow the Tutorial to deploy the charm on MicroK8s.
Short story for your Ubuntu 22.04 LTS:
sudo snap install multipass
multipass launch --cpus 4 --memory 8G --disk 30G --name my-vm charm-dev # tune CPU/RAM/HDD accordingly to your needs
multipass shell my-vm
juju add-model mysql
juju deploy mysql-k8s --channel 8.0/stable --trust # --config profile=testing
juju status --watch 1s
The expected result:
mysql overlord microk8s/localhost 2.9.38 unsupported 22:48:57+01:00
mysql-k8s 8.0.31 active 3 mysql-k8s 8.0/stable 75 10.152.183.234 no
mysql-k8s/0* active idle 10.1.84.74 Primary
mysql-k8s/1 active idle 10.1.84.127
mysql-k8s/2 active idle 10.1.84.73
Check the Testing reference to test your deployment.
