Charmed MySQL K8s
- By Canonical Data Platform
Fencing Async replication
WARNING: it is an internal article. Do NOT use it in production! Contact Canonical Data Platform team if you are interested in the topic.
Pre-requisits
Make sure both Rome
and Lisbon
Clusters are deployed using the Async Deployment manual!
Fencing
In case of emergency failover, and there is a risk of the transaction sets differing between parts of the ClusterSet. To avoid a split brain scenario, where more than one cluster is set as primary
, it’s important to fence all write traffic from the failed primary cluster. For doing so there’s an action fence-writes
juju run -m rome db1/leader fence-writes cluster-set-name=<my-cluster-set>
where cluster-set-name
is a mandatory option to avoid human mistakes (see below).
Note: The action
fence-writes
can be run against any of the Primary Cluster units.
Unfencing
Case the old primary is reestablished and/or have all transactions reconciled, one can resume write traffic to it, by using the unfence-writes
action, e.g.:
juju run -m rome db1/leader unfence-writes cluster-set-name=<my-cluster-set>
ClusterSet name:
The cluster-set-name
can be set on deployment and retrieved using:
juju run db1/0 get-cluster-status cluster-set=true
domainname: cluster-set-bcba09a4d4feb2327fd6f8b0f4ac7a2c
Extra
You can find more details about fencing in official MySQL ClusterSet documentation.
