Charmed MySQL K8s
- By Canonical Data Platform
Removal of Async replication
WARNING: it is an internal article. Do NOT use it in production! Contact Canonical Data Platform team if you are interested in the topic.
Pre-requisits
Make sure both Rome
and Lisbon
Clusters are deployed using the Async Deployment manual!
Detach Cluster from ClusterSet
Note: It is important to switchover the
Primary
Cluster before detaching it from ClusterSet!
Assuming the Lisbon
is a current Primary
and we want to detach Rome
(for removal or reuse):
juju remove-relation async-primary db2:async-replica
The command above will move cluster Rome
into the detached state blocked
keeping all the data in place.
Rejoin detached cluster into previous ClusterSet
At this stage, the detached/blocked cluster Rome
can re-join the previous ClusterSet by restoring async integration/relation:
juju switch rome
juju integrate async-primary db1:async-replica
Removing detached cluster
Remove no-longer necessary Cluster Rome
(and destroy storage if Rome data is no longer necessary):
juju remove-application db1 # --destroy-storage
New ClusterSet from detached Cluster
Convert Rome
to the new ClusterSet keeping the current data in use:
juju run -m rome db1/leader recreate-cluster
