Charmed MySQL K8s
- By Canonical Data Platform
Minor Rollback
Example: MySQL 8.0.34 -> MySQL 8.0.33
(including simple charm revision bump: from revision 43 to revision 42)
WARNING: do NOT trigger
rollback
during the runningupgrade
action! It may cause unpredictable MySQL Cluster state!
Minor rollback steps
- Prepare “Charmed MySQL K8s” Juju application for the in-place rollback. See the step description below for all technical details executed by charm here.
- Rollback. Perform the first charm rollback, the first unit only. The unit with the maximal ordinal will be chosen.
- Resume. Continue rollback to all other units if the first unit rolled-back successfully.
- Check. Make sure the charm and cluster are in healthy state again.
Manual Rollback
After a juju refresh
, case there any version incompatibilities in charm revisions or it dependencies, or any other unexpected failure in the upgrade process, the upgrade process will be halted an enter a failure state.
Although the underlying MySQL Cluster continue to work, it’s important to rollback the charm to previous revision so an update can be later attempted after a further inspection of the failure.
To execute a rollback we take the same procedure as the upgrade, the difference being the charm revision to upgrade to. In case of this tutorial example, one would refresh the charm back to revision 88
, the steps being:
Step 1: Prepare
It is necessary to re-run pre-upgrade-check
action on the leader unit, to enter the upgrade recovery state:
juju run mysql-k8s/leader pre-upgrade-check
Step 2: Rollback
When using charm from charmhub:
juju refresh mysql-k8s --revision=88
Case deploying from local charm file, one need to have the previous revision charm file and the mysql-image
resource, then run:
juju refresh mysql-k8s --path=./mysql-k8s_ubuntu-22.04-amd64.charm \
--resource mysql-image=ghcr.io/canonical/charmed-mysql@sha256:753477ce39712221f008955b746fcf01a215785a215fe3de56f525380d14ad97
Where mysql-k8s_ubuntu-22.04-amd64.charm
is the previous revision charm file. The reference for the resource for a given revision can be found at the metadata.yaml
file in the charm repository.
The first unit will be rolled out and should rejoin the cluster after settling down. After the refresh command, the juju controller revision for the application will be back in sync with the running Charmed MySQL K8s revision.
Step 3: Resume
There still a need to resume the upgrade on the remaining units, which is done with the resume-upgrade
action.
juju run-action mysql-k8s/leader resume-upgrade --wait
This will rollout the Pods in the remaining units, but to the same charm revision.
Step 4: Check
The future improvement is planned to check the state on pod/cluster on a low level. At the moment check juju status
to make sure the cluster state is OK.
