| 6/stable | 81 | 20 Aug 2025 | |
| 6/candidate | 81 | 20 Aug 2025 | |
| 6/beta | 81 | 20 Aug 2025 | |
| 6/edge | 94 | 28 Oct 2025 | |
| 8-transition/edge | 92 | 27 Oct 2025 | |
| 8/stable | 93 | 27 Oct 2025 | |
| 8/candidate | 93 | 27 Oct 2025 | |
| 8/beta | 93 | 27 Oct 2025 | |
| 8/edge | 93 | 27 Oct 2025 |
How to view metrics
You can view Charmed MongoDB K8s metrics in two ways:
Query the metric endpoint
Charmed MongoDB K8s comes with MongoDB Exporter and provides replication and cluster metrics. The metrics can be queried by accessing the http://<unit-ip>:9216/metrics endpoint.
To quickly view them, you can do the following:
- Identify the unit you would like to query by entering
juju status. Choose a unit to gather metrics from and copy its “Public Address” curlthe metrics endpoint for your unit of interest withcurl http://<unit-ip>:9216/metrics. This should show a long set of metrics.
Access metrics with Grafana
Charmed MongoDB K8s provides integration with the Canonical Observability Stack (COS) - which allows you to view the metrics in a GUI.
To view the GUI:
- Deploy the
cos-litebundle in a Kubernetes environment. This can be done by following the deployment tutorial. Wait for thecos-litebundle to become active and idle, by viewingjuju status. Beware to use the following offers which contain theprometheus-scrapeendpoint, essential to our stack (this endpoint still exists but has been removed from the example offer of the bundle):
https://raw.githubusercontent.com/canonical/cos-lite-bundle/09715997467e1b568109064fa17ecefd4b574032/overlays/offers-overlay.yaml
https://raw.githubusercontent.com/canonical/cos-lite-bundle/09715997467e1b568109064fa17ecefd4b574032/overlays/storage-small-overlay.yaml
- Switch back to your model and consume offers from the COS bundle and relate COS bundle to your application:
juju consume <cos-controller-name>:admin/cos.prometheus-scrape
juju consume <cos-controller-name>:admin/cos.alertmanager-karma-dashboard
juju consume <cos-controller-name>:admin/cos.grafana-dashboards
juju consume <cos-controller-name>:admin/cos.loki-logging
juju consume <cos-controller-name>:admin/cos.prometheus-receive-remote-write
juju integrate mongodb-k8s prometheus-scrape
juju integrate mongodb-k8s loki-logging
juju integrate mongodb-k8s grafana-dashboards
- To view the dashboard we need to find the URL of grafana along with the password for the dashboard. Switch to the k8s model hosting the COS-lite bundle and show all applications:
juju switch <cos-controller>
juju status
Under the report of juju status, the IP address of the grafana GUI should be listed as the “Public Address” for the application grafana. Copy this address and navigate to it in your browser. In your browser you should see a login. Use the username admin, to retrieve the password go back to your terminal and run the action: juju run grafana/0 get-admin-password --wait - use this password to access the Grafana Dashboard.
