mongodb-k8s
Charmed Operator for MongoDB
6/stable 81 20 Aug 2025
6/candidate 81 20 Aug 2025
6/beta 81 20 Aug 2025
6/edge 97 20 Nov 2025
8-transition/edge 98 20 Nov 2025
Ubuntu 24.04
8/stable 95 18 Nov 2025
Ubuntu 24.04
8/candidate 95 18 Nov 2025
Ubuntu 24.04
8/beta 95 18 Nov 2025
Ubuntu 24.04
8/edge 102 10 Dec 2025
Ubuntu 24.04
Sharding in Charmed MongoDB K8s
This page goes over the logic and implementation behind sharding in Charmed MongoDB K8s. For information about how sharding works in general, we recommend checking out this page from MongoDB’s official documentation: MongoDB | Sharding in MongoDB.
In Charmed MongoDB K8s, sharding is designed around the idea of multiple juju applications making up the cluster, unlike replication, where multiple units make up the replica set. These different applications act as cluster components such as shards, config-servers, and mongos-routers. In this page, we will describe these components and the charms they are associated with.
Sharded cluster components
config-server
config-servers exist as a configuration of the already existing Charmed MongoDB K8s charm. The config server manages the related sharding applications and is responsible for adding/removing shards, creating users, managing passwords, creating backups, and enabling TLS.
shard
Shards exist as a configuration of the already existing Charmed MongoDB K8s charm. Once deployed as a shard, shards are unable to create users, manage passwords, and create backups.
mongos
The mongos router is present in two forms in Charmed MongoDB K8s:
  1. Cluster admin - In this case, mongos runs as an administrative daemon within the config-server, managing shards, users, passwords, etc. It is not advisable to access this mongos daemon directly in a production environment.
  2. Router for client connections - In this case, mongos runs as a subordinate charm, Charmed Mongos, and acts as an independent router for client applications.
Designed for reduced latency
We designed our deployments around creating the most efficient sharded cluster possible. For this reason, the administrative mongos router runs within the same virtual machine as the config-server. This means that administrative cluster actions do not need to make additional network calls to configure the cluster.
On the Mongos K8s charm, a similar approach is taken for the non-administrative mongos router (i.e. the mongos client router). In this case, mongos is running using the Unix Domain Socket so that client requests to the sharded cluster do not have to make a network call when interfacing with their associated router.
Sharded cluster architecture
The image below depicts an example deployment of a sharded cluster in Charmed MongoDB K8s and the relationships between all components:
A flowchart describing a sharded cluster deployment with two external applications, two shards, and one config-server
For more information about Charmed MongoDB K8s sharded cluster deployments, check the following pages in this documentation:
Replication-only vs. sharded cluster deployments
Some key differences between a bare replica set deployment and a sharded cluster deployment include:
Replication-only Sharded cluster
Requires one MongoDB application Requires multiple MongoDB applications
Can create users via mongodb_client interface Can create users via config-server interface
Can be integrated with legacy interface Cannot be integrated with legacy interface
