| 6/stable | 81 | 20 Aug 2025 | |
| 6/candidate | 81 | 20 Aug 2025 | |
| 6/beta | 81 | 20 Aug 2025 | |
| 6/edge | 97 | 20 Nov 2025 | |
| 8-transition/edge | 98 | 20 Nov 2025 | |
| 8/stable | 95 | 18 Nov 2025 | |
| 8/candidate | 95 | 18 Nov 2025 | |
| 8/beta | 95 | 18 Nov 2025 | |
| 8/edge | 102 | 10 Dec 2025 |
Revision 61 release notes
21 October 2024
Charmed MongoDB K8s Revision 61 has been deployed to the 6/stable channel on Charmhub.
- Highlights and features
- Requirements and compatibility
- Integrations
- Software contents
- Known issues and limitations
- Join the community
Highlights
This section goes over the features included in this release, starting with a description of major highlights, and finishing with a comprehensive list of all other features.
- User Management
- Sharding
- Backups
- Security with TLS
- Accessibility outside of K8s with the mongos-k8s router
- Metrics with COS integration - with all sharding components visible in the same dashboard
Other features
- Audit logging
- Log rotation
- Integration to mongos
For a detailed list of commits throughout all revisions, check our GitHub Releases.
- Juju
v3.*
See the system requirements page for more information about software and hardware prerequisites.
Integrations
See the Integrations page for a list of all interfaces and compatible charms.
Software contents
This charm is based on the Canonical charmed mongodb rock. It packages:
- Percona Server for MongoDB
v6.0.6-5 - MongoDB Exporter
v0.40.0 - mongosh
2.3.1 - Percona Backup for MongoDB
2.4.0
The following issues are known.
- Restores on backups with old passwords will leave clients / operator user locked out of the DB
- Removing a shard before breaking its integration with the config-server results in data loss
- Sharding cluster cannot drain jumbo chunks - draining jumbo chunks requires manual intervention
Join the community
Charmed MongoDB is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
- Check our Code of Conduct
- Raise software issues or feature requests in GitHub
- Report security issues through LaunchPad.
- Meet the community and chat with us on Matrix
- Contribute
