mongodb-k8s
Charmed Operator for MongoDB
6/stable 81 20 Aug 2025
6/candidate 81 20 Aug 2025
6/beta 81 20 Aug 2025
6/edge 97 20 Nov 2025
8-transition/edge 98 20 Nov 2025
Ubuntu 24.04
8/stable 95 18 Nov 2025
Ubuntu 24.04
8/candidate 95 18 Nov 2025
Ubuntu 24.04
8/beta 95 18 Nov 2025
Ubuntu 24.04
8/edge 102 10 Dec 2025
Ubuntu 24.04
Cryptography
This document describes the cryptography used by Charmed MongoDB K8s and Charmed Mongos K8s. We discuss both charms since we acknowledge that Charmed Mongos K8s is a required to access a sharded K8s cluster.
Resource checksums
Charmed MongoDB K8s and Charmed Mongos K8s operators use pinned revisions of the Charmed MongoDB snap. This provides a reproducible and secure environments The snap packages the workloads associated with both charms (percona-server-mongodb, mongodb-exporter, pbm, etc), see Charmed MongoDB snap contents.
Every artifact bundled into the Charmed MongoDB snap is verified against their MD5, SHA256 or SHA512 checksum after download. The installation of certified snaps into the rock is ensured by snap primitives that verify their squashfs filesystems images GPG signature. For more information on the snap verification process, refer to the snapcraft.io documentation.
Sources verification
Charmed MongoDB K8s and Charmed Mongos K8s sources are stored in:
  • GitHub repositories for snaps, rocks and charms
  • LaunchPad repositories for the percona-server-mongodb, mongodb-exporter, and pbm upstream forks used for building their respective distributions
LaunchPad
Distributions are built using private repositories only, hosted as part of the SOSS namespace to eventually integrate with Canonical’s standard process for fixing CVEs. Branches associated with releases are mirrored to a public repository, hosted in the Data Platform namespace to also provide the community with the patched source code.
GitHub
All MongoDB artifacts (including mongos) built by Canonical are published and released programmatically using release pipelines implemented via GitHub Actions. Distributions are published as both GitHub and LaunchPad releases via the central-uploader repository, while charms, snaps and rocks are published using the workflows of their respective repositories.
All repositories in GitHub are set up with branch protection rules, requiring:
  • new commits to be merged to main branches via pull request with at least 2 approvals from repository maintainers
Encryption
Charmed MongoDB K8s can be used to deploy a secure database that provides encryption-in-transit capabilities out of the box for:
  • mongod replica/shard communication
  • mongos router communication
  • External client connection
To set up secure connections to Charmed MongoDB K8s, the database must be integrated with TLS Certificate Provider charms, e.g. self-signed-certificates operator. CSRs are generated for every unit using tls_certificates_interface library that uses the cryptography Python library to create X.509 compatible certificates. The CSR is signed by the TLS Certificate Provider, returned to the units, and stored in a file with limited permissions and stored in Juju Secrets.
When encryption is enabled, hostname verification is turned on for existing connections, including clients, shards, replicas, and routers.
Encryption at rest is currently not supported, although it can be provided by the substrate (cloud or on-premises).
Authentication
In Charmed MongoDB K8s and Charmed Mongos K8s, authentication layers can be enabled for:
  1. MongoDB replica/shard/router communication (i.e. Internal Membership)
  2. Client authentication to MongoDB
Internal Members authenticate using:
  1. KeyFiles using SCRAM-SHA-256 protocols
  2. x.509 certificates
Both KeyFiles and certificates are stored as files with minimal permissions. Note MongoDB disables support for TLS 1.0 encryption on systems where TLS 1.1+ is available.
These files need to be readable and writable by root (as these files are created by the charm), and readable by the snap_daemon user running the Charmed MongoDB snap commands.
Client and router authentication to MongoDB
Clients can authenticate to MongoDB using:
  1. username and password exchanged using SCRAM-SHA-256 protocols
  2. client certificates or CAs (mTLS)
When using SCRAM, usernames and passwords are stored in Charmed MongoDB K8s and Charmed Mongos K8s to be used by the mongod and mongos processes, in peer-relation data and in external relation to be shared with client applications via Juju secrets.
When using mTLS, client certificates are loaded into a tls-certificates operator and provided to the Charmed MongoDB K8s via a plain-text unencrypted relation. Certificates are stored in a file with minimal permissions. Note MongoDB disables support for TLS 1.0 encryption on systems where TLS 1.1+ is available.
Help improve this document in the forum (guidelines). Last updated 10 months ago.
