mongodb-k8s
Charmed Operator for MongoDB
6/stable 117 23 Jan 2026
6/candidate 117 23 Jan 2026
6/beta 117 23 Jan 2026
6/edge 136 06 Feb 2026
8-transition/edge 140 06 Feb 2026
Ubuntu 24.04
8-transition/edge 138 06 Feb 2026
Ubuntu 24.04
8/stable 118 23 Jan 2026
Ubuntu 24.04
8/candidate 118 23 Jan 2026
Ubuntu 24.04
8/beta 118 23 Jan 2026
Ubuntu 24.04
8/edge 142 10 Feb 2026
Ubuntu 24.04
8/edge 141 10 Feb 2026
Ubuntu 24.04
How to migrate to a new a cluster via restore
This page contains the steps needed to prepare for and perform a restore of a backup from a different cluster, i.e. cluster migration via restore.
We will use the following terms:
  • new cluster - the backed-up cluster that we will migrate data from.
  • old cluster - the currently active cluster that will be restored to the state of the new cluster.
  • For bare replica sets:
    • The new cluster has a number of replicas equal to or greater than the old cluster.
      • E.g. Your old cluster had 2 replicas, so your new cluster must have 2 or more replicas
    • See How To > Scale replicas and shards
  • For sharded clusters:
    • The new cluster has a number of shards and replicas equal to or greater than those in the old cluster.
      • E.g. Your old cluster had 2 shards, so your new cluster must have 2 or more shards.
      • E.g. Your old shard had 4 replicas, so your new shard must have 4 or more replicas.
  • Configured settings for S3 storage
  • Backups from the new cluster in your S3 storage
  • Password from your new cluster
Change password of old cluster
The migration process will restore the password from the new cluster to your old cluster. Set the password of your old cluster to the new cluster’s password:
juju run <replica-set name | config-server name>/leader set-password password=<new cluster password>
List all backups
To view the available backups, enter the command list-backups:
juju run <replica-set name | config-server name>/leader list-backups
This shows a list of the available backups similar to the output below. Identify which backup-id corresponds to the new cluster.
    backup-id             | backup-type  | backup-status
    YYYY-MM-DDTHH:MM:SSZ  | logical      | finished
Define remap pattern (sharded cluster only)
If you are running Charmed MongoDB K8s as a bare replica set, you can skip this step.
A remap pattern is a pattern that specifies which old components should be migrated to which new components. They are used when we are migrating to a cluster with new names.
If you are running Charmed MongoDB K8s as a sharded cluster and you wish to migrate to a cluster with new names, you must generate a remap pattern.
The following example shows how to create a remap pattern for a sample cluster migration.
Sample old cluster:
Model    Controller  Cloud/Region         Version  SLA          Timestamp
old-mod  overlord    localhost/localhost  3.1.6    unsupported  17:27:22Z
App            Version  Status   Scale  Charm         Channel   Rev  Exposed  Message
application             active       1  application             0    no
config-server           active       1  mongodb-k8s   6/stable  158  no
shard-one               active       1  mongodb-k8s   6/stable  158  no
shard-two               active       1  mongodb-k8s   6/stable  158  no
Unit                         Workload  Agent   Address       Ports      Message
application/0*               active    idle    10.130.84.77
config-server/0*             active    idle    10.130.84.120
self-signed-certificates/0*  active    idle    10.130.84.32
shard-one/0*                 active    idle    10.130.84.78
shard-two/0*                 active    idle    10.130.84.68
Sample new cluster:
new-mod  overlord    localhost/localhost  3.1.6    unsupported  17:27:22Z
The following would be a valid remap pattern:
config-server-new=config-server,shard-one-new=shard-one,shard-two-new=shard-two
Restore backup
To restore your current cluster to the state of the previous cluster, run the restore command and pass the correct backup-id to the command:
juju run <replica-set name | config-server name>/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ [remap-pattern=<remap-pattern>]
Your restore will then be in progress. Once it is complete, your old cluster will represent the state of the new cluster.
