mongodb-k8s
Charmed Operator for MongoDB
6/stable 81 20 Aug 2025
6/candidate 81 20 Aug 2025
6/beta 81 20 Aug 2025
6/edge 97 20 Nov 2025
8-transition/edge 98 20 Nov 2025
Ubuntu 24.04
8/stable 95 18 Nov 2025
Ubuntu 24.04
8/candidate 95 18 Nov 2025
Ubuntu 24.04
8/beta 95 18 Nov 2025
Ubuntu 24.04
8/edge 102 10 Dec 2025
Ubuntu 24.04
Charmed MongoDB K8s Tutorials > Deploy a replica set > 2. Deploy MongoDB
Deploy MongoDB
Deploying a Charmed MongoDB K8s replica set is a quite straightforward operation with Juju. In this page, you will learn how to deploy and track the charm’s status as Juju sets it up in the background.
Deploy MongoDB with the following command:
juju deploy mongodb-k8s --trust
The --trust flag is necessary to grant the application access to the Kubernetes cluster
Juju will fetch the charm from Charmhub and begin deploying it to the MicroK8s cloud. This process can take several minutes depending on how provisioned (RAM, CPU, etc) your machine is.
Track deployment status
You can check the status of your deployment by running:
juju status --watch 1s --relations
This will display a table with an overview of all the status info of the elements in your juju model, like IP addresses, ports, state, and other useful data. The --watch 1s flag means that it will update every 1s.
For this tutorial, it is recommended to have a separate terminal permanently set to juju status --watch 1s --relations so that you can see what is happening every time you make changes to your juju model. The --relations flag will display additional information regarding integrations (previously known as “relations”), which will be useful later on.
When your MongoDB application is ready, juju status --watch 1s will show something similar to sample output below:
tutorial  overlord    microk8s/localhost  3.1.6   unsupported  15:33:40Z
App          Version  Status  Scale  Charm        Channel  Rev  Address        Exposed  Message
mongodb-k8s           active      1  mongodb-k8s  6/stable    81  10.152.183.20  no
Unit            Workload  Agent  Address      Ports  Message
mongodb-k8s/0*  active    idle   10.1.42.137
To exit the screen with juju status --watch 1s, enter Ctrl + C.
Next step: 3. Access MongoDB
Help improve this document in the forum (guidelines). Last updated 3 months ago.
