mongodb-k8s
Charmed Operator for MongoDB
6/stable 61 15 Nov 2024
6/candidate 61 15 Nov 2024
6/beta 61 15 Nov 2024
6/edge 65 02 May 2025
5/edge 39 14 Dec 2023
Clean up the environment
In this tutorial, we’ve successfully:
  • Deployed MongoDB on LXD
  • Scaled our deployment
  • Added and removed database users
  • Enabled and disabled TLS
You may now keep your MongoDB deployment running to continue experimenting, or remove it entirely to free up resources on your machine.
Remove Charmed MongoDB
If you remove Charmed MongoDB as shown below, you will lose all data stored in MongoDB.
To remove Charmed MongoDB K8s, delete the juju model it is hosted on:
juju destroy-model tutorial --destroy-storage --force
Then, remove the overlord Juju controller. You can see all the available controllers by entering juju controllers.
To remove the overlord controller used in this tutorial, enter:
juju destroy-controller overlord
Remove Juju
If you remove Juju as shown below, you will lose access to any other applications you have hosted on Juju.
To remove Juju altogether, enter:
sudo snap remove juju --purge
You’ve successfully completed our Charmed MongoDB K8s tutorial :tada:
What next?
Join the community!
