Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 193 13 Mar 2024
14/candidate 248 04 May 2024
14/beta 248 04 May 2024
14/edge 251 08 May 2024
Reference > Release Notes > All revisions > Revision 247/248
Revision 247/248 (14/candidate only)
TODO: DD, MM, YYYY
Dear community,
We’d like to announce that Canonical’s newest Charmed PostgreSQL K8s operator has been published in the ‘14/stable’ channel :tada:
AMD64 ARM64
Revision: 247 248
Bugfixes
  • Fixed large objects ownership in PR#390, [DPE-3551]
  • Fixed shared buffers validation in PR#396, [DPE-3594]
  • Fixed handling S3 relation in primary non-leader unit in PR#375, [DPE-3349]
  • Stabilized SST and network cut tests in PR#385, [DPE-3473]
  • Fixed pod reconciliation: rerender config/service on pod recreation in PR#461, [DPE-2671]
  • Updated data-platform-libs: data_interfaces to 34 and upgrade to 16 in PR#454
  • Updated Python dependencies PR#443
  • Unified juju2 and juju3 test suites PR#462
  • Converted all tests from unittest to pytest + reenabled secrets everywhere in PR#452, [DPE-4068]
  • Added check_tls_replication for checking replicas encrypted connection in PR#444
  • Fixed Primary status message after cluster bootstrap in PR#435
  • Improved error message on temporary impossible upgrade in PR#432, [DPE-3803]
  • Check user existence after relation broken for db and db-admin interfaces in PR#425
  • Switched to ruff formatter in PR#424
  • Updated charm libs and switch away from psycopg2-binary PR#406
  • Fixed support CPU in millis in PR#410, [DPE-3695]
  • Block on legacy roles request (suported by modern interface only) in PR#391, [DPE-3099]
GitHub Releases provide a detailed list of bugfixes, PRs, and commits for each revision.
Inside the charms
  • Charmed PostgreSQL ships the PostgreSQL - 14.11-0ubuntu0.22.04.1
  • PostgreSQL cluster manager Patroni - 3.1.2
  • Backup tools pgBackRest - 2.48
  • The Prometheus postgres_exporter - 0.12.1-0ubuntu0.22.04.1~ppa1
  • This charm uses ROCK OCI based on SNAP revision 113
  • This charm ships the latest base Ubuntu LTS 22.04.4
Technical notes
Contact us
  • Raise software issues or feature requests on GitHub
  • Report security issues through Launchpad
  • Contact the Canonical Data Platform team through our Matrix channel.
