Charmed PostgreSQL K8s
- By Canonical Data Platform
14/beta | 248 | Yesterday | |
14/edge | 248 | Yesterday |
Perform a major rollback
Example: PostgreSQL 15 → PostgreSQL 14
Currently, this charm only supports PostgreSQL 14. Therefore, only minor rollbacks are possible.
Canonical is NOT planning to support in-place rollbacks for the major PostgreSQL version change as the old PostgreSQL cluster installation will stay nearby and can be reused for the rollback.
