Charmed PostgreSQL K8s
- By Canonical Data Platform
14/beta | 248 | 03 May 2024 | |
14/edge | 248 | 03 May 2024 |
How to create and list backups
- A cluster with at least three-nodes deployed
- Access to S3 storage
- Configured settings for S3 storage
juju run
injuju v.2.9
juju integrate
replacesjuju relate
andjuju add-relation
injuju v.2.9
Create backups
Once you have a three-node cluster with configurations set for S3 storage, check that Charmed PostgreSQL is active
and idle
with juju status
Once Charmed PostgreSQL is active
and idle
, you can create your first backup with the create-backup
command:
juju run postgresql-k8s/leader create-backup
Tip: To avoid unnecessary service downtime, always use non-primary units for the action create-backup
. Keep in mind that:
- TLS enabled: disables the command from running on primary units.
- TLS not enabled: disables the command from running on non-primary units.
List backups
You can list your available, failed, and in-progress backups by running the list-backups
command:
juju run postgresql-k8s/leader list-backups
