PgBouncer K8s
- Canonical
1/stable | 360 | 20 Dec 2024 | |
1/stable | 359 | 20 Dec 2024 | |
1/candidate | 360 | 18 Dec 2024 | |
1/candidate | 359 | 18 Dec 2024 | |
1/beta | 360 | 16 Dec 2024 | |
1/beta | 359 | 16 Dec 2024 | |
1/edge | 392 | Today | |
1/edge | 391 | Today |
PgBouncer K8s revision 81
Wednesday, December 6, 2023
Dear community, this is to inform you that new PgBouncer K8s is published in 1/stable
charmhub channel for Kubernetes.
The features you can start using today:
- PgBouncer is updated from 1.18 to 1.21 [DPE-3040]
- Open TCP port
6432
on K8s [GH PR#159] - Updated Python library dependencies [GH PR#158]
Bugfixes included:
- Juju Secrets fixes provided by updated data Interfaces library (LIBPATCH 24).
- Fixed GitHub Issue #166 [DPE-3113]
What is inside the charms:
- Charmed PgBouncer K8s ships the latest PgBouncer “1.21.0-0ubuntu0.22.04.1~ppa1”
- The Prometheus pgbouncer-exporter is “0.7.0-0ubuntu0.22.04.1~ppa1”
- K8s charms based on our ROCK OCI (Ubuntu LTS “22.04” - ubuntu:22.04-based)
Technical notes:
- Upgrade (
juju refresh
) is possible from this revision 76+. - Please check the external components requirements
- Use this operator together with a modern operator “Charmed PostgreSQL K8s”.
How to reach us:
Contribute to the project!
