Charmed MySQL K8s
- By Canonical Data Platform
8.0/stable | 180 | 02 Sep 2024 | |
8.0/stable | 181 | 02 Sep 2024 | |
8.0/candidate | 180 | 26 Aug 2024 | |
8.0/candidate | 181 | 26 Aug 2024 | |
8.0/beta | 181 | 20 Aug 2024 | |
8.0/beta | 180 | 20 Aug 2024 | |
8.0/edge | 199 | Today | |
8.0/edge | 198 | Today |
Reference > Release Notes > All releases > Revision 180/181
Revision 180/181
September 2, 2024
Dear community,
Canonical’s newest Charmed MySQL K8s operator has been published in the 8.0/stable channel.
Due to the newly added support for arm64 architecture, the MySQL K8s charm now releases two revisions simultaneously:
- Revision 180 is built for
amd64
- Revision 181 is built for
arm64
TO make sure you deploy for the right architecture, we recommend setting an architecture constraint for your entire Juju model.
Otherwise, you can specify the architecture at deploy time with the --constraints
flag as follows:
juju deploy mysql-k8s --constraints arch=<arch> --trust
where <arch>
can be amd64
or arm64
This release of Charmed MySQL K8s requires Juju v.3.4.3
or 3.5.2+
. See the Technical details section for more information.
Highlights
Below is an overview of the major highlights, enhancements, and bugfixes in this revision. For a detailed list of all commits since the last stable release, see the GitHub release notes.
Enhancements
- Upgraded MySQL from
v8.0.36
→v8.0.37
(see Packaging) - Added support or ARM64 architecture (PR #448)
- Added support for Audit plugin (PR #474) (DPE-4970)
- Add first Awesome Alert Rules (PR #469) (DPE-2477)
- Added support for rescanning cluster for unit rejoin after node drain (PR #433) (DPE-4118)
- Changed binlog retention period (one week by default) (PR #478) (DPE-4247)
Bugfixes
- Removed passwords from outputs and tracebacks (PR #473) (DPE-4266)
- Fixed intermittent issue on AKS deployments (unknown/idle state) (PR #458) (DPE-4850)
- Strip passwords from command execute output and tracebacks (PR #473) (DPE-4266)
- Address drained units rejoining the cluster with a new PV (PR #433) (DPE-4118)
- Ensure username uniqueness (PR #439) (DPE-4643)
- Backup stabilization fixes (PR #444) (DPE-4699)
- Idempotent configure method (PR #451) (DPE-4800)
- Show global-primary on endpoint (PR #440) (DPE-4658)
- Fix metrics-endpoint created on scale up (PR #483)
Technical details
This section contains some technical details about the charm’s contents and dependencies.
Requirements
This release of Charmed MySQL requires Juju v.3.4.3
or 3.5.2+
. See the guide How to upgrade Juju for a new database revision.
See the system requirements page for more details about software and hardware prerequisites.
Packaging
This charm is based on the charmed-mysql
rock. It packages:
- mysql-server-8.0
v8.0.37
- mysql-router
v8.0.37
- mysql-shell
v8.0.37
- prometheus-mysqld-exporter
v0.14.0
- prometheus-mysqlrouter-exporter
v5.0.1
- percona-xtrabackup
v8.0.35
Libraries and interfaces
- mysql
v0
- See the Libraries tab in MySQL VM for the API reference.
- grafana_agent
v0
for integration with Grafana- Implements
cos_agent
interface
- Implements
- rolling_ops
v0
for rolling operations across units- Implements
rolling_op
interface
- Implements
- tempo_k8s
v1
,v2
for integration with Tempo charm- Implements
tracing
interface
- Implements
- tls_certificates_interface
v2
for integration with TLS charms- Implements
tls-certificates
interface
- Implements
See the /lib/charms
directory on GitHub for a full list of supported libraries.
See the Integrations tab for a full list of supported integrations/interfaces/endpoints
Contact us
Charmed MySQL K8s is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
- Raise software issues or feature requests on GitHub
- Report security issues through Launchpad
- Contact the Canonical Data Platform team through our Matrix channel.
