Charmed MySQL K8s
- By Canonical Data Platform
8.0/stable | 180 | 02 Sep 2024 | |
8.0/stable | 181 | 02 Sep 2024 | |
8.0/candidate | 180 | 26 Aug 2024 | |
8.0/candidate | 181 | 26 Aug 2024 | |
8.0/beta | 181 | 20 Aug 2024 | |
8.0/beta | 180 | 20 Aug 2024 | |
8.0/edge | 199 | Today | |
8.0/edge | 198 | Today |
Charmed MySQL K8s revision 127
March 22, 2024
Dear community, this is to inform you that new Canonical Charmed MySQL K8s is published in 8.0/stable
charmhub channel for Kubernetes.
- Updated workload to MySQL 8.0.35 in #360
- Juju 3.1.7+ support in #2037120
- DPE-3402 Update TLS test lib and test charm in #370
- DPE-3617 Add CA chain support in #383
- Add Allure Report beta in #366
- All the functionality from the previous revisions
Bugfixes
Canonica Data issues are now public on both Jira and GitHub platforms.
Highlights for the current revision:
- DPE-3547 Fixed mitigations for container restart in #377
- DPE-3389 Fixed support for rollbacks with incompatible data dir in #385
- DPE-2919 Fixed pod labels update on preemptive switchover in #367
- DPE-3265 Refactored lib secrets in #362
- DPE-2758 Fixed messaging when no bucket + ceph testing in #332
- DPE-3027 Fixed retry policy for is_mysqld_running in #356
- Fixed typo in secrets marker in #380
- Fixed parallel backup tests in #375
- Removed colon from logrotate file path in #351
What is inside the charms
- Charmed MySQL K8s ships MySQL “
8.0.35-0ubuntu0.22.04.1
” - CLI mysql-shell updated to “
8.0.33-0ubuntu0.22.04.1~ppa1
” - Backup tools xtrabackup/xbcloud updated to “
8.0.35-30
” - The Prometheus mysqld-exporter is “
0.14.0-0ubuntu0.22.04.1~ppa1
” - K8s charms based on our ROCK OCI (Ubuntu 22.04 LTS - ubuntu:22.04-based)
- Principal charms supports the latest Ubuntu 22.04 LTS only
Technical notes
- Upgrade (
juju refresh
) is possible from revision 75+ - Use this operator together with a modern operator “MySQL Router K8s”
- Please check additionally the previously posted restrictions
- Ensure the charm requirements met
Project and community
Charmed MySQL K8s is an official distribution of MySQL. It’s an open-source project that welcomes community contributions, suggestions, fixes and constructive feedback.
- Read our Code of Conduct
- Join the Discourse forum
- Contribute and report issues
- Explore all Canonical Data Fabric solutions
- Contact us for all further questions
Please check all the previous release notes if you are jumping over the several stable revisions!
