mysql-k8s
Charmed MySQL K8s
8.0/stable 240 11 Mar 2025
8.0/stable 241 11 Mar 2025
8.0/candidate 240 27 Feb 2025
8.0/candidate 241 27 Feb 2025
8.0/beta 240 25 Feb 2025
8.0/beta 241 25 Feb 2025
8.0/edge 249 26 Mar 2025
8.0/edge 248 26 Mar 2025
Enable Tracing
This guide contains the steps to enable tracing with Grafana Tempo for your MySQL K8s application.
To summarize:
This feature is available for Charmed MySQL K8s revision 146+ only.
Deploy Tempo
Then, deploy the dependencies of Tempo following this tutorial. In particular, we would want to:
  • Deploy the minio charm
  • Deploy the s3 integrator charm
  • Add a bucket in minio using a python script
  • Configure s3 integrator with the minio credentials
Finally, deploy and integrate with Tempo HA in a monolithic setup.
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed MySQL is deployed.
juju offer <tempo_coordinator_k8s_application_name>:tracing
Then, switch to the Charmed MySQL K8s model, find the offers, and integrate (relate) with them:
juju switch <k8s_controller_name>:<mysql_model_name>
:exclamation: Do not miss the “:” in the command above.
Store  URL                            Access  Interfaces
k8s    admin/cos.tempo                admin   tracing:tracing
juju consume k8s:admin/cos.tempo
Consume interfaces
First, deploy Grafana Agent K8s from the latest/edge channel:
juju deploy grafana-agent-k8s --channel latest/edge
Then, integrate Grafana Agent K8s with the consumed interface from the previous section:
juju integrate grafana-agent-k8s:tracing tempo:tracing
Finally, integrate Charmed MySQL K8s with Grafana Agent K8s:
juju integrate mysql-k8s:tracing grafana-agent-k8s:tracing-provider
Wait until the model settles. The following is an example of the juju status --relations on the Charmed MySQL K8s model:
database  k8s         microk8s/localhost  3.5.4    unsupported  16:33:26Z
SAAS   Status  Store       URL
tempo  active  k8s         admin/cos.tempo
App                Version                  Status  Scale  Charm              Channel      Rev  Address         Exposed  Message
grafana-agent-k8s  0.40.4                   active      1  grafana-agent-k8s  latest/edge   93  10.152.183.63   no       grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
mysql-k8s          8.0.37-0ubuntu0.22.04.3  active      1  mysql-k8s                         0  10.152.183.135  no       Primary
Unit                  Workload  Agent      Address       Ports  Message
grafana-agent-k8s/0*  active    idle       10.1.241.255         grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
mysql-k8s/0*          active    executing  10.1.241.253         Primary
Integration provider                Requirer                   Interface              Type     Message
grafana-agent-k8s:peers             grafana-agent-k8s:peers    grafana_agent_replica  peer
grafana-agent-k8s:tracing-provider  mysql-k8s:tracing          tracing                regular
mysql-k8s:database-peers            mysql-k8s:database-peers   mysql_peers            peer
mysql-k8s:restart                   mysql-k8s:restart          rolling_op             peer
mysql-k8s:upgrade                   mysql-k8s:upgrade          upgrade                peer
tempo:tracing                       grafana-agent-k8s:tracing  tracing                regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore section with tempo-k8s as the data source. You will be able to select mysql-k8s as the Service Name under the Search tab to view traces belonging to Charmed MySQL.
Below is a screenshot demonstrating a Charmed MySQL trace:
Feel free to read through the Tempo HA documentation at your leisure to explore its deployment and its integrations.
