mysql-k8s
Charmed MySQL K8s
8.0/stable 240 11 Mar 2025
8.0/stable 241 11 Mar 2025
8.0/candidate 240 27 Feb 2025
8.0/candidate 241 27 Feb 2025
8.0/beta 240 25 Feb 2025
8.0/beta 241 25 Feb 2025
8.0/edge 249 26 Mar 2025
8.0/edge 248 26 Mar 2025
How to enable monitoring (COS)
Offer interfaces via the COS controller
Switch to COS K8s environment and offer COS interfaces to be cross-model related with Charmed MySQL K8s model.
To switch to the Kubernetes controller, for the cos model, run
juju switch <k8s_cos_controller>:<cos_model_name>
To offer the COS interfaces, run
juju offer grafana:grafana-dashboard
juju offer loki:logging
juju offer prometheus:receive-remote-write
Consume offers via the MySQL model
Next, we will switch to Charmed MySQL K8s model, find offers and consume them.
We are on the Kubernetes controller for the COS model. To switch to the MySQL model, run
juju switch <k8s_db_controller>:<mysql_model_name>
To find offers, run the following command (make sure not to miss the “:” at the end!):
juju find-offers <k8s_cos_controller>:
A similar output should appear, if k8s is the k8s controller name and cos the model where cos-lite has been deployed:
Store  URL                    Access  Interfaces
k8s    admin/cos:grafana      admin   grafana:grafana-dashboard
k8s    admin/cos.loki         admin   loki:logging
k8s    admin/cos.prometheus   admin   prometheus:receive-remote-write
Consume offers to be reachable in the current model:
juju consume k8s:admin/cos.grafana
juju consume k8s:admin/cos.loki
juju consume k8s:admin/cos.prometheus
Deploy and integrate Grafana
First, deploy grafana-agent-k8s:
juju deploy grafana-agent-k8s --trust
Then, integrate (relate) it with Charmed MySQL K8s:
juju relate grafana-agent-k8s grafana
juju relate grafana-agent-k8s loki
juju relate grafana-agent-k8s prometheus
Finally, integrate (relate) grafana-agent-k8s with consumed COS offers:
juju relate grafana-agent-k8s mysql-k8s:grafana-dashboard
juju relate grafana-agent-k8s mysql-k8s:logging
juju relate grafana-agent-k8s mysql-k8s:metrics-endpoint
After this is complete, Grafana will show the new dashboards: MySQL Exporter and allows access for Charmed MySQL logs on Loki.
Sample outputs
The example of juju status on Charmed MySQL K8s model:
Model  Controller   Cloud/Region        Version  SLA          Timestamp
mysql  charmed-dev  microk8s/localhost  3.1.6    unsupported  02:20:09+02:00
SAAS        Status  Store        URL
grafana     active  charmed-dev  admin/cos.grafana
loki        active  charmed-dev  admin/cos.loki
prometheus  active  charmed-dev  admin/cos.prometheus
App        Version                  Status  Scale  Charm      Channel     Rev  Address         Exposed  Message
mysql-k8s  8.0.32-0ubuntu0.22.04.2  active      1  mysql-k8s  8.0/stable   61  10.152.183.115  no       Primary
Unit          Workload  Agent  Address      Ports  Message
mysql-k8s/0*  active    idle   10.1.84.116         Primary
The example of juju status on COS K8s model:
cos    charmed-dev  microk8s/localhost  3.1.6    unsupported  02:20:11+02:00
alertmanager  0.23.0   active      1  alertmanager-k8s  stable    47  10.152.183.206  no
catalogue              active      1  catalogue-k8s     stable    13  10.152.183.183  no
grafana       9.2.1    active      1  grafana-k8s       stable    64  10.152.183.140  no
loki          2.4.1    active      1  loki-k8s          stable    60  10.152.183.241  no
prometheus    2.33.5   active      1  prometheus-k8s    stable   103  10.152.183.240  no
traefik       2.9.6    active      1  traefik-k8s       stable   110  10.76.203.178   no
alertmanager/0*  active    idle   10.1.84.125
catalogue/0*     active    idle   10.1.84.127
grafana/0*       active    idle   10.1.84.83
loki/0*          active    idle   10.1.84.79
prometheus/0*    active    idle   10.1.84.96
traefik/0*       active    idle   10.1.84.119
Offer       Application  Charm           Rev  Connected  Endpoint              Interface                Role
grafana     grafana      grafana-k8s     64   1/1        grafana-dashboard     grafana_dashboard        requirer
loki        loki         loki-k8s        60   1/1        logging               loki_push_api            provider
prometheus  prometheus   prometheus-k8s  103  1/1        receive-remote-write  prometheus_scrape        requirer
Connect Grafana web interface
To connect Grafana web interface, follow the COS section “Browse dashboards”:
juju run grafana/leader get-admin-password --model <k8s_controller>:<cos_model_name>
asciicast
