PgBouncer K8s
- Canonical
1/stable | 269 | 11 Sep 2024 | |
1/stable | 268 | 11 Sep 2024 | |
1/candidate | 269 | 09 Sep 2024 | |
1/candidate | 268 | 09 Sep 2024 | |
1/beta | 269 | 09 Sep 2024 | |
1/beta | 268 | 09 Sep 2024 | |
1/edge | 348 | Yesterday | |
1/edge | 347 | Yesterday |
Major Rollback
Example: PgBouncer 2 -> PgBouncer 1
Currently, the charm supports PgBouncer major version 1 only; therefore, minor rollbacks are only possible. Canonical is NOT planning to support in-place rollbacks for the major PgBouncer version change as the old PostgreSQL cluster with the old PgBouncer installation will stay nearby and can be reused for the rollback.
