Charmed MySQL K8s
- Canonical
8.0/stable | 240 | 11 Mar 2025 | |
8.0/stable | 241 | 11 Mar 2025 | |
8.0/candidate | 240 | 27 Feb 2025 | |
8.0/candidate | 241 | 27 Feb 2025 | |
8.0/beta | 240 | 25 Feb 2025 | |
8.0/beta | 241 | 25 Feb 2025 | |
8.0/edge | 249 | 26 Mar 2025 | |
8.0/edge | 248 | 26 Mar 2025 |
Charmed MySQL K8s Tutorial > 4. Manage passwords
Manage passwords
When we accessed MySQL earlier in this tutorial, we needed to use a password manually. Passwords help to secure our database and are essential for security. Over time, it is a good practice to change the password frequently.
This section will go through setting and changing the password for the admin user.
Retrieve the root password
The root user’s password can be retrieved by running the get-password
action on the Charmed MySQL K8s application:
juju run mysql-k8s/leader get-password
Example output:
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results:
password: sQI3Ojih7uL5UC4J1D9Xuqgx
username: root
status: completed
timing:
completed: 2023-02-15 21:51:04 +0000 UTC
enqueued: 2023-02-15 21:50:59 +0000 UTC
started: 2023-02-15 21:51:04 +0000 UTC
Rotate the root password
You can change the root user’s password to a new random password by running:
juju run mysql-k8s/leader set-password
Example output:
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results: {}
status: completed
timing:
completed: 2023-02-15 21:51:37 +0000 UTC
enqueued: 2023-02-15 21:51:34 +0000 UTC
started: 2023-02-15 21:51:37 +0000 UTC
The status: completed
above means the password has been successfully updated. To be sure, call get-password
once again to check that the root password is different from the previous password.
Set the root password
You can change the root password to a specific password by running set-password
juju run mysql-k8s/leader set-password password=my-password
Confirm with get-password
Example output:
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results: {}
status: completed
timing:
completed: 2023-02-15 21:52:47 +0000 UTC
enqueued: 2023-02-15 21:52:45 +0000 UTC
started: 2023-02-15 21:52:46 +0000 UTC
unit-mysql-k8s-0:
UnitId: mysql-k8s/0
results:
password: my-password
username: root
status: completed
timing:
completed: 2023-02-15 21:52:48 +0000 UTC
enqueued: 2023-02-15 21:52:47 +0000 UTC
started: 2023-02-15 21:52:47 +0000 UTC
The root password
should match whatever you passed in when you entered the command.
Next step: 5. Integrate with another application
