mysql-k8s
Charmed MySQL K8s
8.0/stable 240 11 Mar 2025
8.0/stable 241 11 Mar 2025
8.0/candidate 240 27 Feb 2025
8.0/candidate 241 27 Feb 2025
8.0/beta 240 25 Feb 2025
8.0/beta 241 25 Feb 2025
8.0/edge 249 26 Mar 2025
8.0/edge 248 26 Mar 2025
Charmed MySQL K8s Tutorial > 6. Enable TLS encryption
Enable encryption with TLS
Transport Layer Security (TLS) is a protocol used to encrypt data exchanged between two applications. Essentially, it secures data transmitted over a network.
Typically, enabling TLS internally within a highly available database or between a highly available database and client/server applications requires a high level of expertise. This has all been encoded into Charmed MySQL so that configuring TLS requires minimal effort on your end.
TLS is enabled by integrating Charmed MySQL with the Self Signed Certificates Charm. This charm centralises TLS certificate management consistently and handles operations like providing, requesting, and renewing TLS certificates.
In this section, you will learn how to enable security in your MySQL deployment using TLS encryption.
Self-signed certificates are not recommended for a production environment.
Check this guide for an overview of the TLS certificates charms available.
Enable TLS
To enable TLS on Charmed MySQL K8s, we must deploy the self-signed-certificates charm and integrate it with MySQL.
Deploy TLS charm
Deploy the self-signed-certificates charm with the following command:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
Wait until self-signed-certificates is up and active, using juju status --watch 1s to monitor its progress:
tutorial  overlord    microk8s/localhost  3.5.2  unsupported  23:04:02+01:00
App                        Version   Status  Scale  Charm                      Channel      Rev  Address         Exposed  Message
mysql-k8s                  8.0.31    active      2  mysql-k8s                  8.0/stable   36   10.152.183.234  no
self-signed-certificates             active      1  self-signed-certificates   stable   72   10.152.183.76   no
Unit                          Workload  Agent  Address      Ports  Message
mysql-k8s/0*                  active    idle   10.1.84.74          Unit is ready: Mode: RW
mysql-k8s/1                   active    idle   10.1.84.127         Unit is ready: Mode: RO
self-signed-certificates/0*   active    idle   10.1.84.71
Integrate with MySQL
To enable TLS on Charmed MySQL, integrate the two applications:
juju integrate mysql-k8s self-signed-certificates
MySQL K8s is now using TLS certificate generated by the self-signed-certificates charm.
Check the TLS certificate in use
Use openssl to connect to MySQL and check the TLS certificate in use:
> openssl s_client -starttls mysql -connect 10.1.84.74:3306 | grep Issuer
depth=1 C = US, CN = Tutorial CA
Disable TLS
To remove the external TLS and return to the locally generate one, remove the integration from the applications:
juju remove-relation mysql-k8s self-signed-certificates
If you once again check the TLS certificates in use via the OpenSSL client, you will see something similar to the output below:
Issuer: CN = MySQL_Server_8.0.31_Auto_Generated_CA_Certificate
The Charmed MySQL K8s application reverted to the certificate that was created locally during the MySQL server installation.
Next step: 7. Clean up your environment
